Push button 4wd
- Thank you received: 1761
- UKDAN
- Visitor
minibbb wrote:
adamatdraycott wrote: There aren't any really common issues with the electric transfer box
They aren't quite so straight forward when it comes to working on them... But no serious issues
I prefer the manual box as its one less thing to rely on working
04 and 54 are the last manual shift... 05s got the new dash along with the push button transfer
My 05 plate has a manual shift and older dash, thought the facelift was on a 55 plate?
May have been old stock from Febuary that didn't get registered until March
Dan
Thank you for pointing out the limitation to use 4WD only on very slippery or uneven surfaces. I already knew that though.
I personally prefer a lever quite a lot over a pushbutton, simply because the lever is a much more "manly" device, and it suits a vehicle's off-road image much better than some push buttons or (God forbid) touch screens.
However, that personal preference must be put aside when it comes to more important differences between those two Jimny editions, and that is why I am asking about gearing and drive ratios.
11/60,
So are you saying that in 2WD and 4WD-H mode, the electronic Jimny is evidently highly geared, but in 4WD-L mode it is significantly low-geared to perform any demanding uphill crawling or downhill descent? That would mean that it has better fuel economy (and top speed) in normal cruising (2WD), but still does the crawling job in 4WD-L? So, in your opinion, the gear rating of electronic Jimny is not inferior in any way to the gear rating of old manual Jimny?
I would definitely appreciate if some other people would also give their opinions and comments. Especially on the technical questions about gear and drive ratio differences.
- Cap671
- Visitor
- 1066Boy
- Visitor
- Cap671
- Visitor
- Cap671
- Visitor
