BigJimnyMeet 2024
Two 4x4s and no go with lots of snow!
- Sean65
- Visitor
27 Nov 2021 17:44 #240356
by Sean65
Two 4x4s and no go with lots of snow! was created by Sean65
Well, I don't know about the rest of you but we had loads of snow this morning which was just begging to be driven in. Landy off the road waiting for a new chassis and the Jimny, I bought back in May, still on the drive trying to fathom what the noise is it makes from the rear when driving. I am at a loss. I replaced the wheel bearing i thought it may be but no change at all. When driven slowly up and down the drive it seems to only happen in one place and only when under load so jacking up and rotating the wheel makes no sound at all. Any thoughts would be appreciated. The idea was to be a stand in for the Landy in the winter and the first time we have snow.......
- Thank you received: 552
27 Nov 2021 18:45 #240358
by Scimike
Replied by Scimike on topic Two 4x4s and no go with lots of snow!
We had snow, it melted before I sank the first coffee of the of the day!
It will be back.
What's the noise, knocking, buzzing, grinding etc, and why did you think it was the bearing?
Noises at the rear always travel, that means it's never the thing you suspect.
Mike
It will be back.
Mike
- Sean65
- Visitor
28 Nov 2021 12:59 #240361
by Sean65
Replied by Sean65 on topic Two 4x4s and no go with lots of snow!
It's an odd one. A sort of grind and rumble but it's almost like as it moves to a particular point, as if it was a wheel out of shape. Me and mate have both listened inside and out whilst driving and can't identify it. It's weird!! It's not like we don't know live axles but I concede your point. It reminds me of the old days when you thought poor starting was fuel but usually electric and vice versa.
28 Nov 2021 13:15 #240362
by Scimike
That is an odd one. Just thinking outside the box, possible tyre problem? Try swapping the tyres over and see it the noise swaps sides.
I spent months trying to stop a left rear door knock, it turned out to be the exhaust! Tapping the tow bar on the far right.
Currently have a light knock that comes and goes, left side. So far it's evading location, but left spring is the current contender. Snow and cold weather has halted my search.
Good luck with yours.
Mike
Mike
- Thank you received: 1763
28 Nov 2021 14:11 #240363
Replied by Lambert on topic Two 4x4s and no go with lots of snow!
Have you checked the propshaft joints for excessive wear?
- Sean65
- Visitor
28 Nov 2021 19:03 #240372
by Sean65
I have. No obvious play. Drove up the road and heads turning at the noise. Not good
- Thank you received: 584
28 Nov 2021 21:12 #240377
by facade
Replied by facade on topic Two 4x4s and no go with lots of snow!
Have you checked the front?
My old Jimny had a noise from the back axle. Definitely the back axle. Sitting in the back it was miles louder and still coming from behind.
I fitted new rear wheel bearings- no change
I swapped the diff out- no change.
New propshaft spider- no change
I gave up.
A few weeks later the brake pedal started going to the floor, but would pump up. A front wheelbearing had collapsed, and the wobbly disc was pushing the pads right off using up the pedal travel to clamp the disc again.
Fitted the new bearing, and the noise from the back went.
I gave up.
- Thank you received: 79
28 Nov 2021 21:27 #240379
by LesNewell
Replied by LesNewell on topic Two 4x4s and no go with lots of snow!
Maybe a bent rear brake backplate or a stone trapped in there?
- Sean65
- Visitor
29 Nov 2021 07:50 - 29 Nov 2021 09:05 #240381
by Sean65
Backplates seem fine. I have had the brakes apart. I like the idea of back to front noise transmission. When the snow goes maybe i will jack up the front.
Thanks for the answers thus far.
It almost needs somebody walking beside as i drive up the road.
was you noise constant or just in one place as the wheels rotated as a matter of interest?
Last edit: 29 Nov 2021 09:05 by Sean65.
- Thank you received: 116
29 Nov 2021 16:36 #240394
by maverick
Jalapeño, IISY?
Replied by maverick on topic Two 4x4s and no go with lots of snow!
Get ALL 4 wheels off the ground - aka put it on Jack Stands, put it into Low box and 1st gear. and get all 4 wheels rotating.
The ONLY way to check a UJ is to get the Propshaft OFF and feel the play.
I'd remove both rear half shafts and get the Diff out and check that Crown and Pinion has no teeth removed. Removing Diff's will also allow to you check shafts and Brakes.
Jalapeño, IISY?
- Sean65
- Visitor
29 Nov 2021 19:29 #240397
by Sean65
That’s a plan with all four wheel up at the same time. I fear you maybe right. I may have to bite the bullet and pull the half shaft. Perhaps an inspection of the diff oil. It should indicate something. .
29 Nov 2021 19:40 #240399
by LesNewell
I've had stones jammed in the backplate on drum braked vehicles a couple of times. It is generally a grinding noise that is either constant or pulsing as the wheel rotates. My trials car was particularly prone to this until I fitted discs all round.was you noise constant or just in one place as the wheels rotated as a matter of interest?
Time to create page: 0.133 seconds
