Forum
Suzuki Jimny
Jimny Technical
reversing lights
BigJimnyMeet 2024
reversing lights
little boghopper
Topic Author
Visitor
04 Jan 2018 10:28 #188032
by little boghopper
kirkynut, i checked em with the VOM and they work ok, loghts work when shorted out too, what happens in the box to make them work anyone know? just had a box fitted , have they forgotten something?
CharlesS
Visitor
07 Jan 2018 21:52 #188114
by CharlesS
I checked the FSM in Section 7A for the manual transmission and there does not appear to be anything that could be missing.
Have you tried to manually actuate the back up lights with the switch removed from the transmission and plugged in ?
little boghopper
Topic Author
Visitor
08 Jan 2018 09:36 #188121
by little boghopper
charless, no i have tried the switch when its plugged in the wiring , ie connectors pushed together, i just tested the switch taken off the box, and shorted the other points in the connector on the car and the lights worked.. i,ll try it all clipped together then ....
i,ll have a think... good idea charles thanks.
little boghopper
Topic Author
Visitor
14 Jan 2018 15:51 #188368
by little boghopper
i have taken the switch off for the third time, and all works from the switch up, ie pushing the small ball bearing the lights come on, put it in gearbox in doesnt??? i,m wondering if the small ball bearing isnt protruding enough? thats the only thing i can think of now. my plan b was to cut the wires from the switch and run it inside, and have a switch inside.then wire a spotlight on the roof running wires from the existing reversing lights, would this work ? where would be the best place to bring the wire inside ? anyone a good idea? up under gear stick or through with wiring loom? cheers Liam.
Lambert
Offline
Moderator
The quickest Jimny in Harrogate...(that I own)
Thank you received: 1761
14 Jan 2018 16:32 #188371
Err possible. Until very recently reverse lights were not part of the mot but according to my tester the most recent revisions that and fogs plus a few other little bits are becoming tested.
little boghopper
Topic Author
Visitor
Thank you received: 260
14 Jan 2018 22:02 #188393
11/60 wrote: Err possible. Until very recently reverse lights were not part of the mot but according to my tester the most recent revisions that and fogs plus a few other little bits are becoming tested.
Jobs for the boys innit.
Do it right - use Hammerite
When the blue light is flashing I am kidding.
Lambert
Offline
Moderator
15 Jan 2018 05:06 #188400
Yeah it is. He was also saying that there are new classifications, minor fault, major fault and unsafe to drive or something, unroadworthy maybe. Minor being the equivalent of an advisory and major being a fail. Apparently.
little boghopper
Topic Author
Visitor
15 Jan 2018 21:59 #188420
by little boghopper
no martin, it all works fine from switch ?? just not when on box, ive found a hole in the bulkhead i,m just going to run a wire to a switch inside. i did check ball bearing 3 x s though!!! cheers LIam
Thank you received: 740
15 Jan 2018 23:54 #188427
by Busta
The wiring to the gearbox switch comes from inside, under the steering wheel. So rather than running it back in again, find the right colour under the dash and you can run it straight to your switch. For neatness, a k613 switch is a direct fit in the blanks beside the steering wheel.
little boghopper
Topic Author
Visitor
17 Jan 2018 09:04 #188470
by little boghopper
great busta , cheers i,ll try and find em under there bud
Forum
Suzuki Jimny
Jimny Technical
reversing lights
Time to create page: 0.122 seconds
