Thinking about replacing shocks, what should I choose?
- thordur9
30 Nov 2017 15:00 #186892
by thordur9
Replied by thordur9 on topic Thinking about replacing shocks, what should I choose?
hmm, I talked to customer support and they said that are the part numbers for raised height shocks....
- TomDK
30 Nov 2017 15:01 #186893
by TomDK
Replied by TomDK on topic Thinking about replacing shocks, what should I choose?
Oh.. okay. That's helps a lot
Never seen them before. Great
- TomDK
30 Nov 2017 16:05 #186894
by TomDK
I've just been doing some googling on those Bilstein shocks, trying to compare them with what I believed I had found for stock height Jimny.
Also found some measurements on these shocks. Seem mostly like these shocks you've found are for stock height, some shops even mention them as suitable for up to 50mm lowered vehicles. I found these to be around 40-45 cm's extended. My front Fox shocks measure about 55 cm's and are a pretty good fit on +3" springs.
No matter what. Before you buy, I'd suggest you have them give you the exact measurements on shocks
thordur9 wrote: hmm, I talked to customer support and they said that are the part numbers for raised height shocks....
- minitehnicus
30 Nov 2017 19:42 #186898
by minitehnicus
Replied by minitehnicus on topic Thinking about replacing shocks, what should I choose?
This Bilstein shocks are for standard height for sure:
BIL 24-193382
285mm
402mm
BIL 24-193399
303mm
452mm
Standard shocks are:
KYB 343287
277mm
375mm
KYB 343288
300mm
460mm
BIL 24-193382
285mm
402mm
BIL 24-193399
303mm
452mm
KYB 343287
277mm
375mm
KYB 343288
300mm
460mm
- minitehnicus
30 Nov 2017 19:51 - 30 Nov 2017 19:52 #186899
by minitehnicus
Some +5cm lifted Bilstein 5125 shocks are:
33-186504
300mm
465mm
33-233970
330mm
518mm
33-186504
300mm
465mm
33-233970
330mm
518mm
Last edit: 30 Nov 2017 19:52 by minitehnicus.
- TomDK
30 Nov 2017 22:12 - 30 Nov 2017 22:21 #186906
by TomDK
Not that difficult finding bilstein 5125 that fit. It's more to do with finding the correct valving.
I'd say avoid the rough country shocks if bilsteins are already now in consideration. It's a world of difference in quality
I have bilstein 5125 on the rear axle. Can find the model no tomorrow.
Last edit: 30 Nov 2017 22:21 by TomDK.
Time to create page: 0.160 seconds
