BigJimnyMeet 2024
4WD not engaging, indicator light illuminating.
- Thank you received: 17
22 Nov 2017 22:42 - 22 Nov 2017 22:43 #186612
by bryn
4WD not engaging, indicator light illuminating. was created by bryn
I have a 2007 jimmy which occasionally will not engage 4WD even though the dashboard light illuminates. I can eventually get it to engage by pressing the switch to engage 2WD and then 4WD a few times. Not a huge problem at the moment but a little worrying when stuck in the middle of a field.
Appreciated.
bryn
Appreciated.
bryn
Last edit: 22 Nov 2017 22:43 by bryn.
- Thank you received: 1762
23 Nov 2017 04:59 #186620
Replied by Lambert on topic 4WD not engaging, indicator light illuminating.
Could be the solenoids sticking or gunged up?
- florinelu07
- Visitor
23 Nov 2017 05:12 #186621
by florinelu07
Replied by florinelu07 on topic 4WD not engaging, indicator light illuminating.
The light turns solid green or flashes?
Must check:
transfer box (4x4 command bulb)
vacuum solenoids
vacuum switch
vacuum lines
hubs
Must check:
vacuum solenoids
vacuum switch
vacuum lines
hubs
23 Nov 2017 08:24 #186623
by bryn
Replied by bryn on topic 4WD not engaging, indicator light illuminating.
The bulb is a constant green. If it is the solenoids how do I check them.
Thanks
bryn
Thanks
bryn
- florinelu07
- Visitor
23 Nov 2017 08:56 #186625
by florinelu07
constant green means that vacuum circuit is ok.
check hubs and/or transfer box.
15 Jan 2018 17:38 #188410
by bryn
I thought it had cured itself but its come back. I can hear the diff engaging when I select 4x4 but the front wheels don’t actually engage. Constant green light when selected by the switch and same for 4x4L.
To dark this evening to start working on it but I shall check the vacuum hub pipes and hubs first thing. Can you point me in the direction of knowing if its the transfer box.
Much appreciated
bryn
Much appreciated
bryn
- Mraz
- Visitor
15 Jan 2018 17:58 #188411
by Mraz
Replied by Mraz on topic 4WD not engaging, indicator light illuminating.
Hubs do "clack clack" and transfer box does "wuuut"
When in 4WD lift front wheels and go under the car. Try if you can move/spin front driveshaft. If you can spin it than transfer box is not engaging. If you can spin it and wheels start to move then transfer box is not engaging but hubs are. If you can't spin the front driveshaft but can spin the wheels than transfer box is engaging but hubs are not.
17 Jan 2018 13:18 #188478
by bryn
I think I’ve managed to narrow it down to the vacuum system by using the fault finding section on the forum and its an intermittent fault as well just to complicate things. I have;
1, Jacked each wheel up in turn separately , selected 4x4 (light is on) and when in fault I can spin the wheel.
2, Taken of the hubs and checked the teethed collars (clicked them in to place and un clicked them) which are fine and resealed the hubs when back on.
3, Checked the vacuum pipe work for the obvious and cleaned the small air filter.
4, Checked all the connections to the axil/wheel housing.
When it does work I hear a wurr and double click the last click being the vacuum hubs engaging. When not working I don’t hear the final click of the hubs engaging.
Can anyone give me a few pointers and.................................I live in the Wetherby area and does anyone know a good 4x4 mechanic.
Appreciated bryn
Appreciated bryn
17 Jan 2018 13:30 #188480
Not a good 4x4 specialist but i am only in Harrogate if you want a second set of eyes on it?
- florinelu07
- Visitor
17 Jan 2018 13:46 #188481
by florinelu07
Have you checked the vacuum valves? these are quite easy to clean an lube with WD40.
Also the locking hubs should not have any grease in excess or improper seal on the wheel hubs.
If you have access to a manual vacuum pump or a seringe, you can manually lock/unlock each hub via a hose and start from the wheels and move to the vacuum lines and valves to check where is the leakage.
I'm thinking also in fitting a vaccum probe on the sistem to have a live measurement of the pressure (negative) within the circuit, but still no feasible (I mean cheap ) is available.
17 Jan 2018 19:53 #188499
by bryn
Can you point me in that direction please and tips.
Once again thanks
bryn
Once again thanks
bryn
- Visitor
17 Jan 2018 20:09 - 17 Jan 2018 20:10 #188500
Replied by Daniel30 on topic 4WD not engaging, indicator light illuminating.
Last edit: 17 Jan 2018 20:10 by Daniel30.
Time to create page: 0.133 seconds
