BigJimnyMeet 2024
Power loss puzzle
- Lorry
- Visitor
15 Feb 2015 11:37 #137996
by Lorry
Replied by Lorry on topic Power loss puzzle
I also had a similar problem and think we can over think things sometimes, mine was sound until warmed up we had a code reader on and all sorts i then said to my mate you don't think it's something as simple as spark plugs do you? We whipped them out and I would swear they were the same one's that it rolled off the production line with back in 2003 and an iffy lead its a little tornado now once swapped.
- Russ-41
- Visitor
16 Feb 2015 16:31 - 16 Feb 2015 16:32 #138117
by Russ-41
Replied by Russ-41 on topic Power loss puzzle
I think some garages today expect cars to tell them exactly what's wrong and think "stupid computer!" when it doesn't tell them.
I say, stupid technician!
If these on board computers didn't exist, diagnosis of most faults would probably be much quicker
Last edit: 16 Feb 2015 16:32 by Russ-41.
- pam
- Visitor
16 Feb 2015 21:17 #138144
by pam
Replied by pam on topic Power loss puzzle
They did a full service on it and a thorough check up after the second time it spluttered. (£60 of new spark plugs went on ,are they gold plated ????) and it still did it again! I think they were relying on it happening while they were test driving it around and it hasn't happened to them.
It took me one evening and a post on here..... picking up new camshaft sensor tomorrow and hoping, everyone get their fingers crossed, that will fix it.
- pam
- Visitor
18 Feb 2015 17:56 #138323
by pam
The new camshaft sensor did not fix the problem.....................
Any other ideas anyone?
- troggy
- Visitor
18 Feb 2015 19:46 #138349
by troggy
Replied by troggy on topic Re:Power loss puzzle
You sure get the best advice here. It's a great site Mr Lines!
- Basketcase
- Thank you received: 51
18 Feb 2015 19:53 #138352
by Basketcase
Replied by Basketcase on topic Re:Power loss puzzle
There's 2 sensors, what reg is your Jimny? If you open the bonnet and look at the engine from the front there's a sensor on the front of the engine in top right hand corner the crankshaft sensor, have they tried replacing that one?
- Thank you received: 252
18 Feb 2015 20:23 #138357
by j999pre
Grey pick up Jimny
Replied by j999pre on topic Re:Power loss puzzle
That's the camshaft sensor. On the m series the crankshaft sensor is just under the alternator and is often the cause of sputtering and cutting out but normally puts the cel light on and causes the rev counter to spasm
Grey pick up Jimny
- pam
- Visitor
18 Feb 2015 20:41 #138360
by pam
Replied by pam on topic Re:Power loss puzzle
Its 55 plate, mode?, VVT, japanese, M13AA,
So checklist
Plugs new
oil changed
oil filter new
air filter new
Full service
exhaust checked
cam sensor changed
They are talking about going for the petrol pump again which is going to be vvv expensive.
Does anyone know how much Stoneacre Suzuki charge epr hour etc
Giving up on local garage
So checklist
Plugs new
oil changed
oil filter new
air filter new
Full service
exhaust checked
cam sensor changed
18 Feb 2015 20:57 #138363
by j999pre
Grey pick up Jimny
Check the earth on the front of the manifold 10mm bolt. Battery leads tight? Engine earth down near the starter?
Find someone near you with a m13a jimny (doesn't need to be vvt). Swap coils and plug leads if they will. 5 minute job. Go for a run.
If they are really friendly and good with the spanners see if you can try their CRANKSHAFT sensor. Go for a run.
Have they read the fault codes?
Grey pick up Jimny
18 Feb 2015 20:59 #138364
by j999pre
Grey pick up Jimny
My money is still on crankshaft sensor. Take a bottle of water with you. Go for a run until it splutters. Stop. Squirt water on the crankshaft sensor see if it now runs okay. Sounds a bit rough but it's a good test.
Grey pick up Jimny
- pam
- Visitor
18 Feb 2015 21:11 #138367
by pam
No faults showing at all, Dont know anyone else with a jimny .... unless i go accost someone in a carpark lol
Camshaft sensor changed yesterday, drove great to work, approx 25miles but within half a mile (crawling 10mph in traffic) coming home from work it started spluttering again. rested it 2 mins and it set back off again fine.
- Thank you received: 360
18 Feb 2015 21:32 #138373
by Halford
Replied by Halford on topic Power loss puzzle
What about the Exhaust Gas Recirculation valve (EGR valve) ?
If the engine stumbles or stalls at idle or lacks power under load, the EGR may be staying on and not shutting off.
The EGR Valve helps reduce harmful emissions by introducing a small amount of exhaust gas, below the throttle plate, into the intake manifold. This has the effect of cooling the combustion chambers, as the incoming exhaust displaces part of the oxygen in the combustion chamber and takes up volume, even though it does not support combustion.
not an expert though
Time to create page: 0.133 seconds
