BigJimnyMeet 2024
Winch power cable
- Dan_w
- Visitor
05 Feb 2013 15:41 #60964
by Dan_w
Winch power cable was created by Dan_w
Guys does anyone know What gauge cable should I use to relocate the solenoid box higher in the engine bay on my winch? I plan to have it right next to the battery so can reuse the 2 existing cables but need a 3rd length. I have some 20mm squ AWG4 cable in the garage from an old sound instal. Would this be up to the job?
Cheers
Cheers
- TomDK
- Visitor
05 Feb 2013 15:43 #60965
by TomDK
Replied by TomDK on topic Winch power cable
Depends on how big a winch you have.
But in any case, 20 mm2 cable is too small.
You need 35mm2 at least, preferably 50 mm2 if you winch is a 9500 lb or more.
- Dan_w
- Visitor
05 Feb 2013 16:27 #60968
by Dan_w
Replied by Dan_w on topic Winch power cable
Thanks Tom, i had a feeling it would be too small, I will see what I can get hold of and decide where to position it all.
- TomDK
- Visitor
05 Feb 2013 16:32 #60969
by TomDK
No eBay APP ID and/or Cert ID defined in Kunena configurationI bought som 60 mm2 cable from this shop on ebay
But they many different sizes
- mudman
- Visitor
05 Feb 2013 18:49 #60985
by mudman
Replied by mudman on topic Winch power cable
try curd bros on the north farm ind est tn23dg quite cheep auto sparks supler
- adamjimny
- Visitor
05 Feb 2013 20:33 #61014
by adamjimny
Replied by adamjimny on topic Winch power cable
i huse heavy duty jump leads and cut up and put on connectors etc.....works a treat and tested up to 800cca
- Sponnie
- Visitor
05 Feb 2013 20:37 #61018
by Sponnie
Replied by Sponnie on topic Re: Winch power cable
I used 35mm2 as reccomended by Arbil4x4, main uk agents for Warn. Its the same guage they use on their landrover installs for something like a Warn 9.5XP. If you were going great distance then you could consider 50mm2, to account for the voltage drop.
Sent from my GT-I9300 using Tapatalk 2
- TomDK
- Visitor
05 Feb 2013 20:39 #61019
by TomDK
Replied by TomDK on topic Re: Winch power cable
For extreme use 50mm2 cable would be required for a Warn XP motor as it draws 480 amps a full load.
- Sponnie
- Visitor
05 Feb 2013 22:51 #61051
by Sponnie
50mm2 is bigger than the standard Warn cables that were supplied with my winch from new. You are correct about the max draw. I have run a length of 50mm2 to the rear in case I relocate the batteries. 35mm2 is fine for short lengths.
If in doubt call Mr Bowyer. I can't see 35mm2 setting my Jimny on fire.
Sent from my Nexus 7
- TomDK
- Visitor
05 Feb 2013 23:03 - 05 Feb 2013 23:19 #61054
by TomDK
My TDS 9.5c came with 50 mm2 cables. Warn 8274 comes standard with 50-60 mm2 cables.
I just wonder why the Warn 9.5XP winch only comes with 35mm2 cables. It is way underdimensioned for heavy use and long winch pulls. 35mm2 is only suited for up to around 370 amps.
But you're probably right. Okay for occasional Jimny use
Last edit: 05 Feb 2013 23:19 by TomDK.
- Dan_w
- Visitor
06 Feb 2013 02:17 #61061
by Dan_w
Replied by Dan_w on topic Re: Winch power cable
Thanks guys, I was planning on mounting the control box under the bonnet but to do this it looks like it will cost me more than I expected In the mean time I think I will mount it on top of the winch with the standard cable as it will be reasonable protected and move it once I have some spare funds to buy decent cable.
- mudman
- Visitor
06 Feb 2013 10:15 #61080
by mudman
www.halfords.com/webapp/wcs/stores/servl...yId=255204&langId=-1
or use jump leads as said by adamjimny have you tryed ebay?
Time to create page: 0.101 seconds
