front caliper stripdown
- Mumbo Jimbo
- Visitor
- 247sniper
- Visitor
Johnniehec wrote: Kirkynut, did you do the same as me? Stupidly I squirted everything with lubricating oil, well actually it was Tesco's cheapo version which is probably 99% thinners! just had to touch the rubber slider boots and they fell apart, then I had to order the kit to get replacements. Don't put Spray Lube anywhere near the Rubber components!!!
John.
I had used WD40 on the sliders as they were seized as a seized thing! I didn't notice them swell though but they were already tired and perishing and thus in need of replacement!
I had also been using waterproof bearing grease made by Lucas Oils and had not noticed any swelling in the rubbers - however, owing to them being knackered they were not keeping any water out, hence they had seized and kept seizing.
Just in case though, I now have a very large tub of red rubber grease made by Millers I think that came via eBay and will be using that.
The video is very good but how he got the second rubber boot to stay located when he pushed it through so easily I'll never know - mine were a git and I think martin found the same as he mentions it in his guide. Mind you, I didn't take my calipers off the car and did it without disturbing the hydraulics as the calipers themselves are fine and do not need reconditioning yet.
In the summer months I'll re-build the spare set I have unless I can get hold of some of those Lucas ones in the video as their sliders are the bolt that holds the caliper assembly to the caliper bracket and therefore doesn't seize like these Aisin ones.
- Thank you received: 75
cheers
standard jimny - for now
- Thank you received: 153
- 247sniper
- Visitor
Steve.
- SOTA
- Visitor
