Forum
Suzuki Jimny
Jimny Technical
why does my engine cut out?
BigJimnyMeet 2024
Thank you received: 252
18 Apr 2012 19:34 #37935
by j999pre
You only have a Cam sensor then. Its on the back of the cam cover at the top of the engine. An electrical plug and an earth lead should be on it. Its held in with a 10mm bolt.
Grey pick up Jimny
Dutchjimny
Visitor
18 Apr 2012 20:07 #37955
by Dutchjimny
Can i test it with a meter? how many resistance should it have?
18 Apr 2012 21:26 #37968
by j999pre
Next time it cuts out cool it with some water. If it starts then you know its that.
Other thing to consider is a blocked breather or petrol cap. When it cuts out remove the cap, if there is a big vacuum this could be the problem.
Best of luck.
Grey pick up Jimny
ZookFastback
Visitor
18 Apr 2012 21:50 #37971
by ZookFastback
No eBay APP ID and/or Cert ID defined in Kunena configurationThis is link to the cam angle sensor for G13BB engine, on Ebay. Very cheap and easy to replace.
Forum
Suzuki Jimny
Jimny Technical
