BigJimnyMeet 2024
G4 Jimny Rear Wiper Blade Replacement
- Thank you received: 95
13 Dec 2021 16:30 #240616
by Bob1050
G4 Jimny Rear Wiper Blade Replacement was created by Bob1050
Went down to two local motor factors this afternoon and totally failed to source a replacement rear window wiper blade for my 2018 G4 Jimny. No problem buying front blades (lots of options) but the rear one wasn't even listed on their computer systems. Can anyone help me spec the correct 12" blade that will do the job? Any recommendations appreciated.
- Thank you received: 168
13 Dec 2021 16:38 #240617
by 300bhpton
Replied by 300bhpton on topic G4 Jimny Rear Wiper Blade Replacement
try a better motor factors. The rear isn't anything special, just a regular blade and fitment.
13 Dec 2021 16:59 #240619
by Bob1050
Replied by Bob1050 on topic G4 Jimny Rear Wiper Blade Replacement
Thanks for responding but looking along the factor's shelf was like 'confusion marketing' - where a "regular one" wasn't apparent.
- Roger Fairclough
- Thank you received: 194
13 Dec 2021 19:37 #240624
by Roger Fairclough
Replied by Roger Fairclough on topic G4 Jimny Rear Wiper Blade Replacement
Halfords list it as a Bosch A282H @£12.00 and Amazon has it priced at £9.49.
Take your pick.
Roger
Take your pick.
Roger
13 Dec 2021 22:10 #240626
Replied by mlines on topic Re:G4 Jimny Rear Wiper Blade Replacement
Had to go to a dealer in the end as everyone, including Halfords, claimed to have the correct one in their listings and didn't.
Sent from my moto g31(w) using Tapatalk
13 Dec 2021 23:34 #240628
by Bob1050
Replied by Bob1050 on topic Re:G4 Jimny Rear Wiper Blade Replacement
Hi Forum members and many thanks for your informative and considered responses - one of the joys and benefits of this forum. Now I'm sweating as to what my Suzuki dealer is charging for a single 12" wiper blade. I did think that when two well known motor factors couldn't deliver a quick reference/SKU from their computer systems, then there might be an issue with sourcing the part! So it's now looking like the rear window wiper blade is indeed something rather special!
- Thank you received: 552
14 Dec 2021 01:20 - 14 Dec 2021 01:22 #240630
by Scimike
Replied by Scimike on topic Re:G4 Jimny Rear Wiper Blade Replacement
Google suggests the Suzuki part is about £20.
shopsuzuki.co.uk/products/suzuki-jimney-...ine-rear-wiper-blade
How about changing the arm if you can't get blades or don't want to pay stupid prices.
It is after all is said and done nothing special.
Last edit: 14 Dec 2021 01:22 by Scimike.
- Thank you received: 479
14 Dec 2021 07:16 - 14 Dec 2021 07:16 #240632
Replied by Soeley on topic G4 Jimny Rear Wiper Blade Replacement
Over on one of the FB groups apparently these are the Bosch Aero alternatives.
AR13U from Bosch for the rear and
AR16U for the front
AR16U for the front
Last edit: 14 Dec 2021 07:16 by Soeley.
14 Dec 2021 09:35 #240633
by 300bhpton
Eurocarparts has them on offer at the mo.
The 13U is the wrong fitment however and will not work. I have a different blade for the rear, but let me go and check the rear as I haven't fitted it yet.
The 16U fits the front as they are 'retro' fits. i.e. they fit the tradition hook style fitment.Over on one of the FB groups apparently these are the Bosch Aero alternatives.
AR16U for the front
14 Dec 2021 09:54 #240636
It's a private group, so no point t in me linking it, but a few responded to say they had fit them. No mention of the rear not fitting.
I thought most replacement blades came with an assortment of fitting to suit different arms nowadays.
14 Dec 2021 10:21 #240637
by 300bhpton
Ok, so the AR13U is too big really. Sorry getting mixed up. The Land Rover Defender uses 13" blades and the AR13U is indeed a retrofit and will physically fit the arm.
However they are 13" long. The factory blade is about 11 1/2 long. So the 13U will likely overhang the glass, as there isn't much of a gap.
I originally bought a Bosch A281H as it was a flatbalde of the right length. But this does indeed have the wrong fitment.
So I swapped it for a Bosch SP11 which is rated at 11"/280mm
As you can see it is ever so slightly shorter than the factory fit option:
But has the correct fitment:
Incidentally, I found it easier to move the arm upright to remove the old blade (turn wiper on, turn ignition off when in the position you want).
The swept area is slightly less with this blade, but it'll do for now. However if you look at the glass where original was, I think you'd be overlapping the paint with the 13" blade.
- Roger Fairclough
14 Dec 2021 11:41 #240639
by Roger Fairclough
Front wiper blades are 400mm and rear is 300mm.
Roger
Roger
Time to create page: 0.150 seconds
