BigJimnyMeet 2024
Diff Drain Plug Removal
- Thank you received: 1763
19 Jan 2018 14:25 #188582
Replied by Lambert on topic Diff Drain Plug Removal
I agree entirely, it's a rare day that I really need a mechanic. I just have to emphasise the high stakes game that applying heat to a sealed container of flammable liquid is , that's all. Good luck with the job!
- Thank you received: 63
19 Jan 2018 19:27 #188590
by furo
Replied by furo on topic Diff Drain Plug Removal
I gave it a go and unfortunately didn't have any success. For both I used plenty of WD40. With the drain plug I decided to try the chisel technique without using the blowtorch, but it just bit into it and didn't rotate. I tried the blowtorch on one of the panhard nuts and used all my strength from different angles but there was no movement at all. I'm glad I gave it a good try though! I'll take it to the mechanic once we get through this snowy patch.
- Mraz
- Visitor
19 Jan 2018 20:08 #188593
by Mraz
Replied by Mraz on topic Diff Drain Plug Removal
I had the same problem with panhard bolts so I just cut them and put new ones in. Regular M10 if I remember.
19 Jan 2018 20:17 #188594
Replied by mlines on topic Re:Diff Drain Plug Removal
I know it's no consolation to you but the panhard rod bolts are prone to "Galling" or cold welding. The vibration fuses the threads of the nut and bolt together. With them being metric fine threads they become all but impossible to undo
Sent from my Nexus 6P using Tapatalk
19 Jan 2018 21:01 #188596
by furo
Mraz: unfortunately I don't have equipment for doing that but thanks for the suggestion
Mlines: it's good to hear that I'm not the only one! Glad I bought those bigjimny panhard bolts
20 Jan 2018 19:31 - 20 Jan 2018 19:31 #188626
by furo
Last edit: 20 Jan 2018 19:31 by furo.
- Visitor
20 Jan 2018 19:32 #188627
Replied by Daniel30 on topic Diff Drain Plug Removal
That looks fantastic would love to drive in that
Great pictures
Great pictures
20 Jan 2018 20:13 #188631
by furo
Thanks mate, it was so much fun! It's Glen Orchy, near Glencoe.
- Visitor
20 Jan 2018 20:50 - 20 Jan 2018 20:51 #188634
The more I look at the pictures the more jealous I get
In fact can you delete them now pls............
Last edit: 20 Jan 2018 20:51 by Daniel30.
20 Jan 2018 21:27 #188642
by furo
Haha! Sorry about that. Back in slushy Glasgow now
- mickt
- Visitor
21 Jan 2018 12:47 #188671
by mickt
Replied by mickt on topic Diff Drain Plug Removal
As regards the drain plug I am assuming you used a 10mm square bit and not a 3/8 AF as they are so close in size it is difficult to tell which is which. If it was the 10mm did you give the bit a good hit with a hammer when fitted to the plug as that can help loosen any corrosion that is holding it in. It is vital too to keep the plug bit square to the centre of the plug when turning the t bar(as opposed to a ratchet) and that can be done using a jack pressed against the t bar just enough to hold it square and still be able to apply maximum torque. If that all fails you could drill the centre of the plug as you have a replacement to a size big enough to get a hacksaw blade in to cut the thread enough to weaken it to allow the chisel to finish it off.
Time to create page: 0.142 seconds
