She's alive!
- Thank you received: 1761
The good news is that my technique of going to bed and leaving it over night has worked, the revs are now down to 750. I guess a sensor or valve was stuck and has freed itself up
Still got a steamy exhaust and something rumbling at the front of the engine though
- Thank you received: 260
mlines wrote: I will syphon out small amounts...................................................I still cannot believe how instantly it started
Have you not got a mower you can use it in or just keep it for cleaning jobs later.
As for starting that is classic Suzuki. .All the ones I have had that have stood for a long time and that is SJ, Vitara and my gold Jimny all fired up on the button............superb.
So what task is next Martin?
2. O2 sensor, ordered from distributor
3. Bleed brakes (new calipers have been fitted)
4. Head gasket test kit. Ordered and should tell me if the steam in the exhaust is of concern. Water system is fine, no loss of water and no over pressure but I get stream from the exhaust.
The above should get me to MOT test. I will then get the garage to change the clutch ( I hate the Jimny clutch change having done it once)
5. Interior re-fit
Sent from my Nexus 6P using Tapatalk
mlines wrote: its just as if it was supposed to idle at that speed.
Its possible but you'd need a Suzuki scan tool to check the target idle.
I will wait until I have a new lambda sensor in, it was idling ok today for some reasonRhinoman wrote:
Busta wrote: Great video. The engineering in modern Japanese engines never fails to impress me.
My Celerio is a prime example.
I did think it would sort its self out but through use, not sleep. It's had enough sleep!
Just make the journey to the MOT station a long one to get the exhaust nice and hot and to evaporate all that moisture sat in it and I reckon it will be fine. Testing the coolant will settle your mind but I've only heard of one twin cam head gasket having let go. You read more than I do though.
Do part the back box from the exhaust and see what pours out though as I've found that's where a lot of the moisture collects. Mine has dripped from there before being re-sealed for the MOT but the moisture means it's needed sealing twice now. New bolts and some exhaust paste will be needed though.
kirkynut wrote: Do part the back box from the exhaust and see what pours out though as I've found that's where a lot of the moisture collects. Mine has dripped from there before being re-sealed for the MOT but the moisture means it's needed sealing twice now.
This is an interesting couple of sentences. Do you go to the trouble of disconnecting the box?
