SJ Modified front axle
- Smoggy
- Visitor
reaper wrote: Vacuume hubs- when in 2wd the hubs spin free and the t-box doesnt spin the output
Fixxed hubs - when in 2wd the hubs turn the diff and props but the t-box isnt turning the output drive
Sounds like il get even less mpg. God il be in supercharged Range Rover territory at this rate
- vitara_mad
- Visitor
- darthloachie
- Visitor
there is no problem on the road when you are in 2wd as the front drive train isn't engaged
to get the arb locker to work you will need a compressor
- Smoggy
- Visitor
- darthloachie
- Visitor
Smoggy wrote: Yeah thats my next issue darth. I have the output nipples from the diffs but no hoses and compressor fittings. Do I get these when I buy the compressor, im gonna go for the hd type as then i can deflate/inflate the tyres etc. Ive heard the solenoid outputs from the compressor dont come with the compressor kits and i may have to buy them as an extra from ARB
its probably worth having a chat with devon 4x4 as they are importers for ARB
they sell a compressor kit for £150 and the pipe at £1.50 a metre an can probably obtain the solenoids for them
you'll probably need switches 1 for the compressor and on for each ARB
we also have a flashing led for when the front arb is locked ( its best not to put any steering lock on when using the front arb as it will break halfshafts)
- Smoggy
- Visitor
- darthloachie
- Visitor
turned once off road at the top of a climb and broke the halfshaft - now only ever use it in a straight line and switch it out if I need to turn
- Smoggy
- Visitor
I meant off road as in the really sticky stuff.
- Smoggy
- Visitor
- adamjimny
- Visitor
sent from my Samsung Galaxy S2 using Tapatalk
