Possible change to the way we sell T-Case kits...
- g187eev
- Visitor
The customer would have the coice to either :
- swallow the cost and not return their Jimny t-gase gear.
- Remove and return the gear from the jimny box, and receive £50 back by cheque/refund to card.
- Return the gear and receive a free ORA goodie to the value of £50
Any thoughts?
RB
Is it not possible to just remove the pick up ring from the Jimny box and use it in the sj box? This is what I did when I bought my rocklobster from you a couple of years ago. Surely this would be simpler and save the expense of transporting the ring backwards and forwards. It was a simple matter to press the ring onto the flange.
Peter
- g187eev
- Visitor
Not sure whats happened with your kit, maybe you picked up a box which already had a modified/re-manufactured speedo ring on it?
The ID and thickness of the factory Jimny ring and the dimensions it needs to be a totally different...
postage for this part would only be 2/3 pounds...
RB
- Thank you received: 153
The Jimny transfer box will become redundant and isn't worth anything, so even though in good condition, it would probs just be skipped.
Awful getting old!
- g187eev
- Visitor
The only thing that is useful in there is the speed'o gear. Which is where this plan comes in to play.
RB
SJ boxes are getting very hard to get hold of.
I think a trade in will be the best option, this will help our credit cards after buying goodies
- Gromit
- Visitor
Gromit wrote: Where are all these cheap transfer boxes on Ebay ?, I need one and the cheapest is £75 !!!!
I'm going to remove mine shortly! As I am going to fit a SJ box, Has got KAP heavy duty mounts! Sure we could sort something out, I pass your area a'lot so could drop off
- Gromit
- Visitor
Would you take £50 for it ?
I have bent the stick with heat to suit a 2"body lift, just then bungee tied it back as It jumped out once, needs slightly more bending. I can pop it out this weekend if you want.
PM sent.
- aniesigh
- Visitor
