That code reader socket
  • helijohn
27 May 2013 09:06 #71845 by helijohn
That code reader socket was created by helijohn
OK, so I am looking for the code reader socket in the place behind the glove box; so where is the code reader please?? :unsure: :(
  • VAXXi
27 May 2013 09:11 #71846 by VAXXi
Replied by VAXXi on topic That code reader socket
OBD reader ? on LHD cars, it's just behind the steering wheel cover (bottom part), at the lower edge of the plastics.
  • helijohn
27 May 2013 09:25 #71850 by helijohn
Replied by helijohn on topic That code reader socket
Hi yes the OBD reader but mine is a RHD Jimny if that helps. ;)
  • markyp2000
27 May 2013 09:32 #71852 by markyp2000
Replied by markyp2000 on topic That code reader socket
Right hand side put head in foot well and look up
  • helijohn
27 May 2013 10:04 - 27 May 2013 10:28 #71854 by helijohn
Thanks, off to look now!
Yessss found it near the tunnel just above my left ankle. Has three leads so is it OBD11?
Last edit: 27 May 2013 10:28 by helijohn.
27 May 2013 11:50 #71862 by Rhinoman
Replied by Rhinoman on topic That code reader socket
Unlikely to be OBD2 if its a metal cased ECU, you need to check which pins are populated on the connector. You probably have pin 9, pin 16 and pin 4/5 which is a Suzuki proprietary protocol.
Time to create page: 0.355 seconds
