My Jimny named Grin Giver
23 Jun 2020 06:53 #223891 by kirkynut
Replied by kirkynut on topic My Jimny named R&B
If you're anywhere near Sussex, Rhino Ray will make a cage for a reasonable price I believe.
A friend did mine for me in South Essex.
30 Jun 2020 16:16 #224293 by jackonlyjack
Replied by jackonlyjack on topic My Jimny named R&B
Time for front axle strip down
Paint my swivel's
Trailgear shafts n cv's
26 spline side gears
And new kingpin bearings if needed
26 Jul 2020 15:06 - 07 Aug 2020 07:36 #225702 by jackonlyjack
Por15 on the swivel's
Modified landy engine mounts to fit transfer cradle
Measurements
X2 cut to fit driver side
This one cut and shaped to fit rockwatt cradle
Not sure you would need to modify for standard transfer mounts
Last edit: 07 Aug 2020 07:36 by kirkynut.
29 Jul 2020 18:20 #225831 by jackonlyjack
Modified bushes fitted
While i was under their had a look at rear engine mount
Central bolt looked off to oneside
So got a new one from the spares shelf
Old one not delaminated but rubber really soft
30 Jul 2020 17:02 #225864 by Riccy
Replied by Riccy on topic My Jimny named R&B
They look a good fit B)
The following user(s) said Thank You: jackonlyjack
30 Jul 2020 18:18 #225871 by jackonlyjack
They do fit well Riccy
Got fed up of the bolt through one's moving to one side slightly. think that's due to the bolt through's only being M8
Landy one's are M10 so no movement to be had,the transfer is lifted around 15mm higher up now ;)
Expecting some vibration from them....but knowing they are now super strong i can live with vibration :laugh:
Time to create page: 0.210 seconds
