Mr Green
  • rogerdadodger
10 Feb 2013 12:50 - 10 Feb 2013 13:01 #61898 by rogerdadodger
Mr Green was created by rogerdadodger
Well after wanting a little Jimny for a while I've found one that was in the condition & price range that I wanted!
I've been after one that runs/drives & is in a OK condition but could do with a bit of TLC! I plan to have it back on the road for next winter & will then just tax & insure it for 6 months while the Shetland weathers rubbish!
First few things to do once I've picked it up are getting it ready for an MOT (it failed on a rotten boot floor) & had a few advisory's (worn drop links, oil leak, bushes, etc) & I'll get the cambelt done as i'm unsure when it was last done as there's no service history. It does however come with new drop links, poly bushes, 5 of the 3 spoke alloys with OK tyres & 5 of the OZ alloys with pretty good tyres that are on it in the picture. Does anyone know where I can I get replacement centre caps for the OZ wheels??
Then I think I'll look at mods like a high lift kit, bigger wheels/tyres, snorkel etc but will be on the look out for some bits while I'm doing the other MOT work!
I'll put up some better pictures once I've got it home :woohoo:
Cheers
Dodge
Last edit: 10 Feb 2013 13:01 by rogerdadodger. Reason: Working with the pictures!
  • dirtydogz
10 Feb 2013 13:13 - 10 Feb 2013 14:01 #61904 by dirtydogz
Replied by dirtydogz on topic Mr Green
Welcome to the BIG JIMNY forum Roger, green is the best colour ,as for the centre cap some one will have one on the forum.
I've made your photos larger so we can see them better, next time just click on the (insert box).
DIRTYDOGZ B)
Last edit: 10 Feb 2013 14:01 by dirtydogz.
  • Tadpole
10 Feb 2013 13:58 #61914 by Tadpole
Replied by Tadpole on topic Mr Green
I needed a set of caps for my alloy wheels & did a search on ebay for 75mm, this item #280939770370 .
Turns out I found some plastic pipe end caps that worked a treat, they are much like the emergency petrol caps ‘fit all sizes’ hth ... ;)
  • adamjimny
10 Feb 2013 14:31 #61922 by adamjimny
Replied by adamjimny on topic Mr Green
im sure i have some jimny plastic ones if that helps?
  • rogerdadodger
10 Feb 2013 17:39 #61961 by rogerdadodger
Replied by rogerdadodger on topic Mr Green
So there's no metal caps for the wheels? :(
Any other major problems I should be looking out for?
I canna wait till Tuesday to get it home & have a good dig around it :woohoo:
  • rogerdadodger
14 Feb 2013 19:10 #62566 by rogerdadodger
adamjimny wrote: im sure i have some jimny plastic ones if that helps?
I'll take a picture of mine tomorrow & you can see if its the same as the one you have!
Cheers
Time to create page: 0.172 seconds
