Kirkynut's Jimny (aka Daddy's Tractor) - The Evolution continues...
  • helijohn
04 Nov 2015 17:59 #155347 by helijohn
Replied by helijohn on topic Kirkynut's Jimny - The Evolution continues...
kirkynut wrote: Oil change done today.Kirkynut
Been working hard innit. :laugh:
Regarding SAE 5W am I right in thinking the oil will be much the same viscosity at a certain temperature. Assuming the ambient temperature is 14°C the oil will flow much the same 5/30 or 10/30. If the temp drops to -20°C then the 5W oil will flow better. :unsure:
  • Daniel30
04 Nov 2015 19:50 #155359 by Daniel30
Replied by Daniel30 on topic Kirkynut's Jimny - The Evolution continues...
Good job jobbed then ;) do you not have to change the oil filter when you do an oil change?
  • helijohn
04 Nov 2015 19:55 #155360 by helijohn
Daniel30 wrote: Good job jobbed then ;) do you not have to change the oil filter when you do an oil change?
I do religiously. Sometimes I change the filter and keep the oil. ;)
04 Nov 2015 23:50 #155376 by kirkynut
Er... yes. I didn't mention the filter as I've never known anyone to change the oil and not the filter.
04 Nov 2015 23:56 #155377 by kirkynut
The first number is it's viscosity when hot and thinnest and the second when it's cold and thickest.
So when hot it'll be a little thinner and get to places better but might get past the rings a little easier as a result and burn a little more. We are talking such a small amount though.
When cold it'll be a little thinner than the 10w40 I've been using so will be better for cold starts.
I've used fully synthetic too, so it ought to do a better job too!
  • Daniel30
05 Nov 2015 06:46 #155382 by Daniel30
As I have no mechanical knowledge whatsoever :woohoo: I was just wondering as you hadn't covered many miles between changes so I was just checking
Cheers
Time to create page: 1.036 seconds
