standard panard rods
  • adamjimny
10 Jan 2011 14:32 #9306 by adamjimny
standard panard rods was created by adamjimny
are the standard panard rods hollow? if so what size tube internal diameter are they?
  • adamjimny
10 Jan 2011 15:09 #9307 by adamjimny
Replied by adamjimny on topic Re: standard panard rods
also what is the length of the standard ones? and what size bolt is used at both ends?
asking as i want to make my own adjustable ones cheaply as i think i could do it for £20 tops for both
  • vitara_mad
10 Jan 2011 15:21 #9309 by vitara_mad
Replied by vitara_mad on topic Re: standard panard rods
i am going to make my own adjustable rod for the front as the rear already had one fitted when i got the jimny but i was just going to cut the standard rod & put a adjustable bit in but it would deffo be better made out of some stronger tube cus the standard ones are so thin & weak
  • adamjimny
10 Jan 2011 15:27 #9311 by adamjimny
thats what im doing 2mm walled tube with rose joints each end that screw into a weld in threaded part so no need for bushes ever again and slightly adjustable.
all comes in just under £20 but i need to know the bolt sizes and length of the standard rods or adjustable rods
  • Strek
10 Jan 2011 15:41 #9313 by Strek
Replied by Strek on topic Re: standard panard rods
Nice idea! Post pictures and drawings of this project! It should be easy! Good luck, will follow this thread!
10 Jan 2011 16:36 #9320 by mlines
Replied by mlines on topic Re: standard panard rods
Won't this create a direct metal to metal path from the axles to the chassis? I would have thought that you would have increased noise and vibration?
