What colour antifreeze should I use?
15 Apr 2023 13:10 #248583
by Vandoni
What colour antifreeze should I use? was created by Vandoni
I noticed my coolant is terrible and will flush the system as instructed in the maintenance manual, what colour antifreeze should I use?
also I'll keep the 50/50 blend ratio since the temps here go under -10 C in the winter.
15 Apr 2023 13:39 #248584
Replied by jackonlyjack on topic What colour antifreeze should I use?
If you're giving it a good flush
any type will be ok
because you will not be mixing different types
any type will be ok
15 Apr 2023 13:43 #248585
by Vandoni
Replied by Vandoni on topic What colour antifreeze should I use?
Wouldn't the wrong colour damage gaskets or something like that? I heard that you should use the recommended color but in the manual it says that any is good as long as its base is etyhil glycole or smth like that
15 Apr 2023 14:00 #248586
ethylene glycol is what is used from factory
i have green ethylene glycol based in atm
Have used red oat based in my previous jimny with no problems
15 Apr 2023 14:05 #248588
by Vandoni
So with the Jimny it doesn't really matter what I use as long as I clean really well beforehand?
also the expansion tank has this yellowish "sludge" inside and sticking on the little rod connected to the expansion tank cap, should I be worried?
15 Apr 2023 14:26 #248589
do you have the yellow ish sludge inside the oil filler cap too
any anti freeze will be ok ..........just don't mix with other types ( red with red,blue with blue,green with green)
yellow sludge could be caused by condensation from short runs
OR failing head gasket
The following user(s) said Thank You: Vandoni
Time to create page: 0.200 seconds
