Jimny gen4 AT tire recommendation
- Chop
24 Jan 2022 12:43 - 24 Jan 2022 16:14 #241454
by Chop
Jimny gen4 AT tire recommendation was created by Chop
Hi guys,
I have an automatic Gen4 Jimny and have been driving it for about 7 months now. I've been looking to upgrade the stock tyres and am not sure on what would be the best option for me.
Due to regulatory reasons in my country I can only go for the stock size 195/80/15 which greatly limits my options, and no MTs either since the load code doesn't match.
Basically the options are:
1) Toyo open country at+
2) General grabber at3
3) Cooper discoverer at3 sport
4) Yokohama geolander at g105
The car is used only on weekends and mainly for offroading, road use is limited to going back and forth to the off-road route, or family visits every once in a while.
In terms of offroading, it's mostly rock climbing and rocky terrain in general, so good grip and a strong sidewall are top priority. Every once in a while it'd be a mud trip or a sand trip, so decent mud capability is a bonus (I understand it's going to be very limited due to my constraints).
Any input would be greatly appreciated
Sent from my SM-G973F using Tapatalk
Last edit: 24 Jan 2022 16:14 by Chop.
- Thank you received: 667
24 Jan 2022 13:15 #241456
Replied by DrRobin on topic Jimny gen4 AT tire recommendation
All three look sensible choices, but I haven't had any of these although there are people on here who will have had them and can comment.
I use Yokohama Geolandar A/T GO15 which is available in your size, but might not be stocked where you are. I also use Hankook Dynapro ATm (also in your size) which is a little more aggressive AT tyre pattern and should have a bit more grip in mud and snow. Again not sure if they are stocked in your area?
Robin
Robin
- Chop
24 Jan 2022 14:17 #241458
by Chop
Replied by Chop on topic Re:Jimny gen4 AT tire recommendation
I believe the Yokohamas might be available as my friend just bought a set for his GV.
They do look very similar to the stock tires though, albeit with a tougher sidewall.
Are they any good in the mud or rocky hills?
24 Jan 2022 15:00 #241459
by lightning
Replied by lightning on topic Re:Jimny gen4 AT tire recommendation
Have the stock tyres been unsatisfactory? l've only done light off reading in ours but they seem okay, l imagine they are road biased so not great for rock crawling.
Grip isn't great on greasy roads though, l nearly ended up in a field in Norfolk when l took a corner in the rain.
- Chop
24 Jan 2022 15:12 #241460
by Chop
In mud I've found them to get plugged up really fast and becoming quite slippery afterwards.
That being said I'm definitely not in a hurry to replace them.
Replied by Chop on topic Re:Re:Jimny gen4 AT tire recommendation
The stock tires are fine for the most part but they are getting worn, losing some tread chunks due to being torn off, and it feels like the smooth side wall is a tear waiting to happen. They've also been lacking some grip on powdery desert rocks and steep gravel ascends.lightning wrote: Have the stock tyres been unsatisfactory? l've only done light off reading in ours but they seem okay, l imagine they are road biased so not great for rock crawling.
- Chop
24 Jan 2022 16:12 #241462
by Chop
Just checked and the Yokohamas are available as well, will add them as an option
