5mm Wheel Spacers
  • Sean65
07 Dec 2021 10:57 #240535 by Sean65
5mm Wheel Spacers was created by Sean65
Hello.  Does anyone know where I can get the above, please   I have searched all over Google and most are either bigger or have the wrong centres  I bought some universal ones but the id was wrong.  The wheel weights are fouling on the track rod end so only needs a smidgen more clearance. Cheers .
07 Dec 2021 12:50 #240538 by Roger Fairclough
Replied by Roger Fairclough on topic 5mm Wheel Spacers
Some thoughts Sean65.
Are the wheel weights the sort that clip to the wheel edge? If yes, remove them and check if that solves the problem. If yes, rebalance with adhesive weights fitted to c/line of wheel.
If no then would you be happy with the loss of 5mm from wheel studs? If yes can you get the universal spacers machined to fit? If no try local machine shop to make you a pair.
Roger
  • Sean65
07 Dec 2021 13:32 #240539 by Sean65
Replied by Sean65 on topic 5mm Wheel Spacers
Thanks Roger. That was where I was thinking of going with spacers as they are not especially expensive if only I could find some. 5mm and still just about enough thread. I was pondering 5 mm washers as a temp but that would limit contact patch although the wheels are steel so doubt they will flex.
07 Dec 2021 15:42 #240540 by Roger Fairclough
Please please please, don't use washers. You must have wheel to hub contact for safe operation.
Roger
07 Dec 2021 16:00 #240542 by Lambert
Replied by Lambert on topic 5mm Wheel Spacers
I'm confused about how the wheel weights are contacting the track rod end, are the wheels the standard Jimny ones or something after market?
  • Sean65
07 Dec 2021 16:40 #240543 by Sean65
Don’t worry Roger. They would only be to gauge the clearance distance whilst rotating the wheel on the jack.
I had assumed they were standard wheels but maybe not.
Time to create page: 0.186 seconds
