Keep brake backing plates on or remove them ?
  • Dirtbird
17 Sep 2021 08:03 - 17 Sep 2021 08:06 #238701 by Dirtbird
Lads do any of you take of the brake backing plates or do ye just leave them on?
Last edit: 17 Sep 2021 08:06 by Dirtbird.
17 Sep 2021 09:00 #238702 by Roger Fairclough
The illustration is of a drum brake system and the backing plate is an essential part of the system as just about everything is mounted onto it. If you are converting to a disc brake system, then the backing plate, as illustrated, is not required. A disc plate system fitted by the car makers will have a backing plate fitted but it is there purely as a dirt/dust shield. This shield will have a cut out to allow the fitting of the caliper.
Roger
  • Dirtbird
17 Sep 2021 11:22 #238708 by Dirtbird
Replied by Dirtbird on topic Keep brake backing plates on or remove them ?
Roger
Rodger putting the calipers back on the front axel today and was just thinking of taking off the backing plates, wondering would it really matter. In the past id get them dinged and they would rub on the disc, out with pliers, and pull them away from the disc and off you go again.
17 Sep 2021 11:31 #238709 by Roger Fairclough
It depends whether or not there are vital parts attached to the backing plate. Items such as brackets for brake pipes or hoses will need replacing with specific items but generally it can be done.
Roger
  • Dirtbird
17 Sep 2021 15:07 #238725 by Dirtbird
The diagram wasn't great should have used a Suzuki front axel image .
17 Sep 2021 16:54 #238728 by jackonlyjack
I removed mine as they where nearly rotted through (fronts)
They hold nothing in place
Time to create page: 0.186 seconds
