2003 Jimny making metalic screeching noise on morning startup
07 Jul 2021 14:32 #236492 by bonairediver2021
Hello Jimny Experts!
My used 2003 Jimny (automatic transmission) 170,000+km... now making metallic-like screeching noise on first start up in the morning... it sounds like metal on metal.....but the noise fades after about 1 minute and doesn't come back upon subsequent startups later in the day.
Can anybody give me a suggestion on what this noise might be?  Could it be a sign of a big problem about to happen?  Could something need lubrication perhaps....or transmission fluid low.... the car's transmission was not great when I got the vehicle (used from Japan).... as it jerks when going into 2nd gear.... but I just needed a cheap 'island car' to get around and don't mind the jerking as its not terrible yet, but maybe that sound is connected to the wonky auto transmission?
I don't really have any skills as a mechanic, but is there any easy to do lubrication I can do for the car to keep it going as long as possible?
Anthony
07 Jul 2021 17:36 #236504 by Lambert
If you're not that mechanical first check the transmission oil level there is a dipstick near the firewall it's probably red in colour. Also as well as checking the level have a sniff of the oil on the stick it shouldn't smell burnt, then if you're able to access a professional workshop and get them to do a transmission oil and filter swap that may well help with the jerky transmission. As for the screech the fact that it is intermittent is going to hinder diagnosis, most of the likely culprits would do it every time you start the car.
07 Jul 2021 18:21 #236505 by lightning
Have you checked the auxiliary drive belt? That can make a loud screeching noise on startup, if it's loose or worn out.
07 Jul 2021 18:40 #236506 by fordem
The alternator drive belt is what I'd be checking - a loose or worn belt will slip under load, typically just after startup when the system is trying to recharge the battery, as the battery charge comes up, the load is reduced and the slip (and screech) gradually get less until they stop.
07 Jul 2021 18:50 #236508 by Lambert
As he said in his other thread the belts have been adjusted and no longer scream.
07 Jul 2021 21:53 #236511 by lightning
A spray of WD-40 on the belt will prove it's not that. Worn belts can still screech if adjusted.
Time to create page: 0.527 seconds
