G13BB wiring
- gsalini
26 Mar 2021 20:14 #234050
by gsalini
G13BB wiring was created by gsalini
Evening all.
Im doing a turbo project for my G13BB SOHC engine. Unfortunately for me I cant find any wiring diagrams for my exact model of car. Its a 2004 spanish soft top with the previously mentioned engine model. Whats unusual is that it has both cam and crank sensors but the cam is a hall effect 3 wire sensor and the crank is a VR 2 wire sensor. Can anyone point me in the direction of where the crank cables go to on the ECU?
I would use the cam for ignition alterations but it seems my G13BB uses the crank as primary!
Any help at all would be great. Thanks
27 Mar 2021 08:21 #234062
by Old Neil
Replied by Old Neil on topic Re:G13BB wiring
Definitely a Martin question, I've got a late model G13BB jimny in Western Australia dosnt have crank angle sensor i can't speak for other countries, hope you are going to upgrade crank and rods standard crank is carst also arp head bolts multi layer steel head gasket also upgrade fuel system even if you fabricated parts your self still costly and teething issues
- Owl
30 Mar 2021 09:20 - 30 Mar 2021 09:21 #234125
by Owl
Replied by Owl on topic Re:G13BB wiring
Yes Neil I'm on Eastern side Australia and only have a cam angle sensor no crank angle sensor. Jimny hasn't produced any wacky idle symptoms yet, since putting in a new fuel pump. Owl
Last edit: 30 Mar 2021 09:21 by Owl.
30 Mar 2021 12:47 #234127
by Old Neil
Replied by Old Neil on topic Re:Re:G13BB wiring
Good to hear you sorted your jimny I'm still not happy with mine waiting on another part here's hopingOwl wrote: Yes Neil I'm on Eastern side Australia and only have a cam angle sensor no crank angle sensor. Jimny hasn't produced any wacky idle symptoms yet, since putting in a new fuel pump. Owl
04 Apr 2021 07:35 #234221
by Old Neil
Well that didn't work new part arrived fitted car runs better but didn't fix the problem if i had any hair i would be pulling it out by now
- Owl
04 Apr 2021 13:19 - 04 Apr 2021 13:21 #234223
by Owl
Yep Neil, I hear your pain, My Jimny gave me a familiar fault once more, driving down the freeway sitting on 85 to 90kms per hour, engine decides to shut off, and come back on , back and forth in that manner for about 10 to 15 secs, and then I stopped at the traffic lights and it idles nicely and drives off as if nothing is wrong. No check engine light but the engine management hiccups to the extreme ?? Has to be the ECU epilepsy.
There is other very subtle intermittent symptoms, very faint misfire, run-on feel (its not the IAC sensor), engine lacking power, high fuel consumption, and at the severe end it engine shuts down and then comes back. Always starts ok. And it runs really smooth at times.
Last edit: 04 Apr 2021 13:21 by Owl.
Time to create page: 0.440 seconds
