Gen 4 Headlight Bulb Replacement?
- Groenewald
26 Mar 2021 08:00 #234033
by Groenewald
Gen 4 Headlight Bulb Replacement? was created by Groenewald
My Gen4 is a GA model with what Suzuki refers to as Halogen Multi Reflector headlights.
I want to swap these out with something better. The GL models have an LED Projector according to Suzuki SA.
What are my options for upgrading the headlights? Do the Gen4s also use the H4 light fitting?
26 Mar 2021 08:13 #234034
Replied by Soeley on topic Gen 4 Headlight Bulb Replacement?
26 Mar 2021 09:36 #234035
by Dan
Replied by Dan on topic Gen 4 Headlight Bulb Replacement?
I was very relieved when I saw that page in the manual, as I have all of those as spares that I had bought in for previous cars.
Its good that Suzuki haven't fitted anything obscure into these.
- GeezerDan
26 Mar 2021 09:40 #234036
by GeezerDan
Replied by GeezerDan on topic Gen 4 Headlight Bulb Replacement?
I'm interested as to whether an LED bulb could be fitted to an SZ4/GA model too.
26 Mar 2021 15:30 #234043
by fordem
Replied by fordem on topic Gen 4 Headlight Bulb Replacement?
As far as I know, Suzuki does not just swap the bulb, they use a completely different headlamp. I believe they also use a different fog lamp assembly on the LED equipped models, so if you're trying to duplicate what they have, you need more than just an LED bulb.
Having said that - there are H4 LED bulbs that can be fitted in place of H4 halogen bulbs, but I would not recommend them, LED bulbs in a lens/reflector combination designed for a halogen bulb will not give you the appropriate beam pattern (which is why no vehicle manufacturer that I know of does that), and may be illegal in your neck of the woods.
The following user(s) said Thank You: GeezerDan
29 Jul 2021 21:31 #237138
by Coco BT
Replied by Coco BT on topic Gen 4 Headlight Bulb Replacement?
any recommendation for upgraded bulbs in my commercial SZ4?
what do people go for, the usual Phillips extremes etc?
Time to create page: 0.396 seconds
