1999 Jimny Heater Core Hose
- Reason2doubt
05 Jan 2021 21:03 - 05 Jan 2021 21:17 #231546
by Reason2doubt
1999 Jimny Heater Core Hose was created by Reason2doubt
Hi everyone,
Just about to flush my heater core as one pipe is significantly colder than the other leading me to believe it is blocked to some extent however I've been wiggling the inlet hose to see if they were stuck and it started to disintegrate and now leaks a little. I would like to replace both of them if possible.
Would anyone happen to know the inner diameter of the hose I would need (pictured)? Edit: or know a suitable replacement?
Last edit: 05 Jan 2021 21:17 by Reason2doubt.
- X8GGY
05 Jan 2021 21:18 #231547
Replied by X8GGY on topic 1999 Jimny Heater Core Hose
Surely the ID of the rubber hose is the same as the OD of the steel pipe it's connected to?...
- Reason2doubt
05 Jan 2021 21:34 #231550
by Reason2doubt
Replied by Reason2doubt on topic 1999 Jimny Heater Core Hose
Yes, fair point. Just wanted to ask in case there was some hidden wisdom out there...
05 Jan 2021 21:36 #231551
by Scimike
Replied by Scimike on topic 1999 Jimny Heater Core Hose
Whats been said ^^^^.
Measure the OD of the metal pipe and get a rubber hose with a ID no larger, ideally slightly smaller, than the metal pipe OD.
Only other option is new OEM pipe I suspect.
MIke
MIke
- Reason2doubt
05 Jan 2021 21:40 #231552
by Reason2doubt
Thank you Scimike that's useful to know!
- Thank you received: 1999
06 Jan 2021 05:50 #231558
Replied by Lambert on topic 1999 Jimny Heater Core Hose
Be careful about how you manipulate the metal pipes as when they move relatively to the heater matrix they can start leaking. Unless the older ones are different the pipes are kinda crimped into bosses on the core and disturbing them after years of immobility is not good.
The following user(s) said Thank You: Reason2doubt
Time to create page: 0.225 seconds
