Tow bar GEN4
- Foxtrot
04 Aug 2020 10:38 #226063
by Foxtrot
Tow bar GEN4 was created by Foxtrot
I am trying to get a tow bar fitted to my Gen4, the dealership doesn't fit detachable tow bars? I have contacted specialist tow bar fitters and they seem to use the Brink tow bar but it will need the bumper to have a cut to accommodate it.
Has anyone got a Brink detachable tow bar and is it easy to attach and take off?
- CC Baxter
04 Aug 2020 11:16 #226069
by CC Baxter
Replied by CC Baxter on topic Tow bar GEN4
The genuine Suzuki part is detachable so heaven knows what your dealer is on about. Why not buy something you like the look of and fit in yourself? Towbars are generally very easy to fit, only the wiring pack (if you need it) will take a little more effort. Chris
- Roger Fairclough
- Thank you received: 225
04 Aug 2020 11:32 #226071
by Roger Fairclough
Replied by Roger Fairclough on topic Tow bar GEN4
The genuine Suzuki tow bracket uses a detachable swan neck because a fitted ball would partially obscure the number plate. The swan neck is also very long so that it hangs out past the spare wheel. The Suzuki wiring loom uses a 13 wire system so be prepared to modify the connection to whatever you are towing if needed. This loom requires a power supply so Suzuki technicians take this from the fuse box in the passenger footwell. The tow bracket and wiring loom are sold separately so you could make up your own loom if you so wish. That way you could stick to the 7 pin system.
Roger
Roger
The following user(s) said Thank You: Foxtrot
- Roger Fairclough
04 Aug 2020 11:41 #226072
by Roger Fairclough
The Suzuki Tow-bar (detachable) is 72901-78ROO-000 and it's listed at £343.00 with a fitting charge of £66.00 ( 1 hours work )
The loom is 990E0-78R66-000 @£129.50 with fitting cost of £49.50 (0.8 hours).
Prices incl.VAT
Roger
Prices incl.VAT
Roger
- Foxtrot
04 Aug 2020 12:11 #226073
by Foxtrot
Replied by Foxtrot on topic Tow bar GEN4
Thanks for the info Roger, it's very useful, I don't think I am up to fitting it myself. I have had this problem before with this dealership..
- Roger Fairclough
04 Aug 2020 12:34 #226075
by Roger Fairclough
Hi Foxtrot.
Obviously I don't know your technical ability and as the dealership fitting charge is only £66.00, then for peace of mind that is the logical way to go. Also you would need axle stands and a helper to slot it into position.
On the other hand if you want to DIY then there are plenty of people here to offer advice.
Roger
Roger
Time to create page: 0.217 seconds
