Petrol leak
27 May 2020 07:43 #222860 by BGBrit
Petrol leak was created by BGBrit
After a few weeks of getting a whiff of petrol fumes I decided today to check this out... I discovered a leak- a damp area - running from the top of the petrol tank to the underside of it, and after shutting off the engine I could hear a hiss coming from the petrol tank area itself. I suspect and perished hose or a loose connection as I don't see how a puncture to the metal tank top surface would be likely. Has anyone had a similar problem and what was your fix? The tank still holds petrol it's not gushing out.
Tony.
27 May 2020 11:33 - 27 May 2020 11:34 #222868 by Max Headroom
Replied by Max Headroom on topic Petrol leak
Not on a JImny but I had a similar thing happen on another vehicle - the way the tank was made was like... imagine a washing-up bowl with a flat lid welded over the top.
...The welded seam had started rotting. It only leaked when the tank was full, and as I'm a big believer of leaving a tank full rather than empty, in order to reduce condensation, it had to be replaced
Last edit: 27 May 2020 11:34 by Max Headroom.
The following user(s) said Thank You: BGBrit
  • CC Baxter
27 May 2020 12:27 #222871 by CC Baxter
Replied by CC Baxter on topic Petrol leak
It could be the gasket on the fuel gauge sender but I confess I've never had reason to inspect a Jimny tank. Chris.
27 May 2020 12:47 #222872 by BGBrit
Replied by BGBrit on topic Petrol leak
I was surprised at this too, on a Jimny, the fact is over the 50 years of car ownership, new and old bangers, this is my first experience of a leaky tank. Does anyone know the proceedures to drop a tank for inspection? Seems like the prop would need removing too... First time for everything.
Tony
  • CC Baxter
27 May 2020 15:10 #222892 by CC Baxter
Somewhere on the forum there is a detailed feature on removing the tank ( I think it's got something to to with rust prevention), hopefully someone will chime in. Only ever had a problem with a S800 coupe where the tank was inside the car! Thank goodness we've moved on from that safety feature. Chris
27 May 2020 15:24 #222893 by BGBrit
That would be great if someone could point me in that direction of removal... One other thought, is there a removable inspection cover under the seats to get access to the tank top, I'm sure it's from there any repairs could be carried out. Only I have heard the prop shaft needs to be removed and the tank dropped to gain access to the connections which seems a hassle of sorts.
Cheers
Tony.
Time to create page: 0.267 seconds
