Ring and pinion
  • VITAC
28 Mar 2020 20:58 #220378 by VITAC
Ring and pinion was created by VITAC
Hi guys ... Does anybody know this pinion ring set. Is made in china and i have second thoughts as i don t know the manifacturer.
I have already placed a M16A motor that can easily run the 205/80/16 tyres. The problem is that the clunch already has a very hard time especialy in the city .This will go worse if i go to 235/70/16 tyres. So a reduction of 13% will be really ok. My vvt has a dif ratio 4.3 . So what this set promise i ll get this 13% reduction
Please check the link
#Aliexpress US $399.00 | Jimny Car Styling Front And Rear Final Reduction Gears Set 4.625/4.875 Ratio
a.aliexpress.com/_dX1Dh7u
  • Jasongds
28 Mar 2020 22:21 #220388 by Jasongds
Replied by Jasongds on topic Ring and pinion
Surely it's your bearings you need to be top quality,Toyo etc,
28 Mar 2020 22:26 #220389 by sniper
Replied by sniper on topic Ring and pinion
Raptor do a 4.63
H&M do a 5.12
sniper
The following user(s) said Thank You: VITAC
  • VITAC
29 Mar 2020 01:42 #220393 by VITAC
Replied by VITAC on topic Ring and pinion
Anybody tested these ...or will break apart at the fist slap:)
29 Mar 2020 10:27 #220402 by Lambert
Replied by Lambert on topic Ring and pinion
As suggested above there are more locally manufactured products available with a much higher quality reputation. Value for money is more important than initial cost to purchase.
29 Mar 2020 13:17 #220420 by Busta
Replied by Busta on topic Ring and pinion
A cheaper and less risky option would be fitting the transfer case from an automatic vvt Jimny.
Time to create page: 0.512 seconds
