Aluminium Epoxy?
- wilt
16 Mar 2020 12:58 #219924
by wilt
Aluminium Epoxy? was created by wilt
Hi,
Can anyone suggest, apart from pulling the Engine out how to repair a crack in Engine Block/Timing Case,the location being where the Alternator adjuster retaining Screw is tightened I noticed this as I was about to change the Belts,can anyone name a good Ally/Metal Bond Epoxy & what would the success rate would be?I'm guessing there is someone out there that has used such stuff ?
Keith
Keith
16 Mar 2020 15:08 #219925
by Keithy
Replied by Keithy on topic Aluminium Epoxy?
I'd use any of the magic metals.....I have a £500 tub of ceramic carbide I use for bodg...er repairing unique parts.....and a tig welder if I want a proper job.
Saw a Cosworth race head repaired with JB weld.....still running afaik.
16 Mar 2020 15:44 #219928
by Bob1050
Replied by Bob1050 on topic Aluminium Epoxy?
Magic metals - might hold or might not? Can't say I've been impressed to date. Tend to think of it as an aesthetic bodge material and on an engine block (with heat cycles) I have serious doubts as to longevity of 'repair'. Not what you want to hear but I've got to be honest.
- wilt
16 Mar 2020 17:26 #219937
by wilt
Replied by wilt on topic Aluminium Epoxy?
Thanks for the reply I cant get doin taking the engine out gonna try & slacken the Bolt & hopefully get the Belts changed just have to tighten it up very gingerly
Keith
Keith
- wilt
16 Mar 2020 17:36 #219939
by wilt
16 Mar 2020 18:54 - 16 Mar 2020 18:54 #219944
Replied by Riccy on topic Aluminium Epoxy?
I would be tempted to drill it out and put a bolt through with a nylock nut and a washer at each side, as well as the magic metal stuff on the crack.
The nut/bolt/washers will spread the load around the hole rather than in it directly, hopefully making it last longer for you.
While the belts are off have a check for play in the crank pulley. Its usually that on its way out that kills off belts
Last edit: 16 Mar 2020 18:54 by Riccy.
Time to create page: 0.398 seconds
