Spare wheel question
- Radupuh
15 Feb 2020 21:19 #218563
by Radupuh
Spare wheel question was created by Radupuh
Hello,
I did some more work on my new Jimny, including a new set of 4 Maxxis Trepador Radial MT tires ( www.maxxis.com/catalog/tire-3-104-trepador-radial-m8060 ).
I didn't worry too much about the spare tire as I don't have a spare wheel yet (long story short, the alloy wheel I got from the previous owner is too thick to be mounted on the car) but now I want to look into this aspect too.
The problem is that the Trepadors have a directional thread pattern, so a 5th Trepador would be a lousy spare tire (as it would run backwards on one side).
What I'm thinking is getting a different MT tire with a non-directional thread pattern for the spare wheel. Would that work well enough?
What I'm interested in is something I can put on the car in case of a flat tire off-road and be able to drive it back to civilization without transmission damage. Tire rotation likely won't come into play, as I don't expect to do more than 4-5000 km/year with the Jimny.
15 Feb 2020 21:28 #218565
Replied by jackonlyjack on topic Spare wheel question
I have directional tyres for trialling 195/80/16
Also my spare is actually a different size 205/80/16
But down to having remoulds x4 the sizes match in circumference
My spare is kept in the back so doesn't look out of place against the others
15 Feb 2020 21:39 - 15 Feb 2020 21:41 #218566
by Scimike
Yes it will be fine.
It makes sense to keep the same size (unless it can't be avoided) and construction (radial / cross-ply) as the main vehicle tyres, but it will not cause any transmission issues having different tread patterns. Just treat it as a spare and get the original back on as soon as it's fixed.
Replied by Scimike on topic Spare wheel question
Radupuh wrote: Hello,
Last edit: 15 Feb 2020 21:41 by Scimike.
16 Feb 2020 00:08 #218571
by kirkynut
Replied by kirkynut on topic Spare wheel question
A directional tyre is fine as a spare. Why does it matter if it's running the wrong way for a few journeys until the original is fixed?
It doesn't have one of those soppy viscous centre diffs that requires the tread depths to be the same or it will wear out etc.
The spare wheel spacers can be found here:
www.jimnybits.com/jimny/jimaccessories/s...re-wheel-spacer.html
- Thank you received: 1999
16 Feb 2020 05:16 #218572
Replied by Lambert on topic Spare wheel question
In my Subaru days I ran various different types of directional tyres over the years and always as sets of 5, on the odd occasion that I had a puncture and had to run one backwards it never presented me with a problem and wherever you are in the UK you are not going to be too far from a tyre place that you can't get the puncture fixed or the spare remounted within a day.
- Radupuh
16 Feb 2020 07:13 #218575
by Radupuh
My understanding has always been that a directional thread running the wrong way has pretty bad handling and traction.
Replied by Radupuh on topic Spare wheel question
kirkynut wrote: A directional tyre is fine as a spare. Why does it matter if it's running the wrong way for a few journeys until the original is fixed?
Time to create page: 1.150 seconds
