Gearing Question (again!)
  • X8GGY
  • Platinum Member
  • Platinum Member
  • but currently AWOL
06 Aug 2018 13:22 - 06 Aug 2018 14:09 #194865 by X8GGY
I was walking the dogs over the weekend, and thinking, as you do...
You know my Gold Jimny is a VVT, and to correct the gearing (for 235/.75/15s) I've fitted earlier ./ non-VVT transfer box and diffs...
So, if someone had an earlier Jimny / non-VVT - is the reverse possible to correct the gearing? i.e. swap the gearbox to a VVT one? Will it fit? And are my gearing assumprions right?
Taking it further... could you do the same and swap the engine for a 1.6 ? i.e. 1.6 Liana engine and a VVT gearbox? Would that fit and work?
Last edit: 06 Aug 2018 14:09 by X8GGY.
06 Aug 2018 16:33 #194875 by Riccy
Replied by Riccy on topic Gearing Question (again!)
as long as its an M series engine, parts seem to be interchangeable (except trying to put a vvt engine into a non vvt car - see James Priestly as he's been having trouble trying that).
I had the R72 vvt gearbox and have changed it to the earlier r7me box. there was some welding on the rear bracket needed. I suspect to get the R72 box into a non vvt jimny would mean altering or moving the chassis crossmember that the rear engine mount goes onto as its further back on the VVT chassis.
Also beware the vvt r72 box is known for bearing failure, making it a weaker choice compared to the older r7me box.
Grimjeeper is the best site ive seen for comparing ratios and the various gearing ratios for the Jimny are in the wiki, bung some numbers in and see what you get!
an example would be for a non vvt jimny wanting to run 31" tyres, just swap the diffs to vvt diffs and its corrected about perfectly, maybe a bit poor in low box tho :laugh:
  • X8GGY
  • Platinum Member
  • Platinum Member
06 Aug 2018 20:46 #194881 by X8GGY
Replied by X8GGY on topic Gearing Question (again!)
Hmmm, thanks Riccy ;)
Dave
06 Aug 2018 21:46 #194883 by yakuza
Replied by yakuza on topic Gearing Question (again!)
Partly due to the gearing the R72 is weaker. You put more of the torque to be transmitted by the gearbox when more of the gearing has to be done by it.
I would not recommend the R72 to anyone. after the noise became apparent it was just 15km and it seized. The boxes from 2005 to approx 2009 are the worst. The ones after that have better closed bearings.
For me it was both cheaper and easier to just swap the transfer gears to 17%/87%. By doing so I also moved roughly 17% more torque over to the transfer box from the gearbox so hopefully my second gearbox will now live longer than my first one did..
10 Aug 2018 09:37 #194968 by Busta
Replied by Busta on topic Gearing Question (again!)
VVT diffs and a 1.6 is a good combination in a pre-VVT Jimny. It gives a small gearing reduction and a noticeable increase in power.
  • X8GGY
  • Platinum Member
  • Platinum Member
15 Aug 2018 10:43 - 15 Aug 2018 10:44 #195140 by X8GGY
Riccy wrote: an example would be for a non vvt jimny wanting to run 31" tyres, just swap the diffs to vvt diffs and its corrected about perfectly, maybe a bit poor in low box tho :laugh:
Doing some maffs on that...
The optimum size would appear to be a 30"x9.5" tyre, which is a good size for a Jimny? :)
earlier Non-VVT diff "final drive" ratio is 3.909
later VVT diff final drive ratio is 4.33
So 4.33 / 3.909 = 1.1077
Looking at tyres -
Standard 205/75/15 = 682.5mm diameter
235/75/15 = 727.50 diameter, so 727.50 / 682.5 = 1.0659 a bit low
31"x10.5" = 775 diameter, so 775 / 682.5 = 1.1355 a bit high
So, 30"x9.5" = 750 diameter, so 750 / 682.5 = 1.0989 ... about right ? B)
Last edit: 15 Aug 2018 10:44 by X8GGY.
Time to create page: 0.239 seconds
