What brand of manual locking hubs do you use? What’s the best manual hubs to buy?
- Thank you received: 683
07 Sep 2018 19:06 #195771
Replied by jackonlyjack on topic What brand of manual locking hubs do you use? What’s the best manual hubs to buy?
After a recent p&p I am seriously considering going back to vac hubs
2 wheel low is something I really miss
But I will carry manual hubs just in case
- jim
07 Sep 2018 19:31 #195773
by jim
Replied by jim on topic What brand of manual locking hubs do you use? What’s the best manual hubs to buy?
Nice work Ninecherries you have been busy with your upgrades. As soon as I start getting issues with mine I'll follow what you've done. Have you managed to block off the vacuum pies to stop the 4x4 flashing?
- NineCherries
07 Sep 2018 23:32 #195777
by NineCherries
Replied by NineCherries on topic Re:What brand of manual locking hubs do you use? What’s the best manual hubs to buy?
Yeah needs must, it’s been an diy filled year for the Jimny
I did block off the pipes but found my fault was a possibly a combination of things so really the pipes being blocked is only to stop water getting into the hubs and the now redundant pipes. I bypassed the vacuum switch In the engine bay so it all works the way it should (and now flashing dash light), 4wd is now reliable for play days and the coming winter
- Caelite
08 Sep 2018 01:31 #195780
by Caelite
Replied by Caelite on topic What brand of manual locking hubs do you use? What’s the best manual hubs to buy?
Hey, pretty cool this thread popped up as I have been considering manuals. I'm wondering if someone can confirm or deny a couple of things I have heard about them.
1. Can you use the 4wd-L with the hubs unlocked? Effectively giving you 2wd-L And does this work for moderate road use? (think <10mi at <40mph across the ruralest of unpoliced Scottish roads with an unspecified tonnage of plant trailer on the back). Or will it send all your power away spinning up the open diff?
2. Another old wife's tail I've heard, with vehicles with locked centre diffs, can you drive on hard surfaces with 4wd with only one hub locked (4x3 essentially) with the wind up 'escaping' out the open wheel?
- Thank you received: 1869
08 Sep 2018 06:05 #195783
Replied by Lambert on topic What brand of manual locking hubs do you use? What’s the best manual hubs to buy?
2x4 low with manual hubs open is a definite thing and for me the most useful thing about the hubs.
You can run with just one hub open but the other wheel wouldn't get any power sent to it as it will just follow the path of least resistance to the open hub. This would put undue wear into the front diff as it would be spinning constantly. Don't bother as it has absolutely no benefit.
- NineCherries
12 Sep 2018 22:14 #195958
by NineCherries
2wd L does work for sure. Car thinks it’s in 4wd L, props turn but the wheels are not being driven as the hubs are disengaged. Never needed to use it but tried it just to find out.
Time to create page: 0.661 seconds
