ET value issue ?
  • jimknows
10 years 3 months ago #170978 by jimknows
ET value issue ? was created by jimknows
Hello,
I have a question and i hope somebody can think of a solution (if there is any).
On my jimny i had the original old sportive wheels with ET value 5 ?
With that the breaks worked perfect and i didnt feel anything in the break pedal.
But when i switched to DOTZ HAMMADA DARK wheels (which has ET value 0) i do feel something in the break pedal. Not sure how te describe it. Sort of bumps...
Anyway, from what i've heard in the garage it has to do with the difference of the ET value i have now. I do use spacers but they are not causing it. Everything from breaks are already replaced.
So does anybody had this before, or is there a way to solve this?
The photo is just to show...
10 years 3 months ago #170993 by kirkynut
Replied by kirkynut on topic ET value issue ?
I can't think how wheel offset can affect brake pedal feel!
I can't how the process of changing the wheels over could cause it either though.
Have you got the old wheels and tyres to pop back on to see if the brakes feel the same on those?
  • jimknows
10 years 3 months ago #171037 by jimknows
Replied by jimknows on topic ET value issue ?
Hello Kirkynut, thanks for replying....
I know its not easy to say what's wrong, but i appreciate every feedback i can get.
To answer your question....some time ago when i switched tires i did noticed it and we did try it with the normal tires and wheels...
Then i was gone...(as i recall) But my front brake discs were checked and even replaced to be sure, and back wheels are checked to. You can even feel it while driving not to fast and pulling the handbrake a little. You can feel it shaking a little bit...
But im just saying what the garage told me... the ET thing....
Best chance i have is to ask here , hoping someone might know something about this..
10 years 3 months ago #171039 by Busta
Replied by Busta on topic ET value issue ?
If you can feel it when applying the handbrake, it has nothing to do with the front disc brakes or the wheel offset.
  • jimknows
10 years 3 months ago #171040 by jimknows
Ok, but what other options are there? It was ok with the normal wheels...
10 years 3 months ago #171046 by Lambert
Replied by Lambert on topic ET value issue ?
Firstly the new wheels, have they been checked for accuracy, are they round and true? Secondly have the tyres been checked for accuracy, are they all balanced and free from sidewall damage like eggs? Thirdly have the symptoms with the hand brake been replicated with the new wheels swapped front to back? Fourthly have the symptoms with the hqnd brake been replicated with the old wheels on the back? Fifthly you say you have spacers on the hubs, do they have a centering flange on their outside face and is it acting correctly with the centre bore of the new wheels?
At the moment i would be suspecting one or more of the new wheels to be possibly buckled, not seated properly or a tyre to be at fault but it is highly unlikely that the different off set has any bearing on the problem.
