Fog Light Issue
  • Statey
05 Jan 2016 22:03 #159833 by Statey
Fog Light Issue was created by Statey
Hopefully someone can help!
A while ago I removed the front bumper and took the factory fitted fogs off to fix the crack in it.
It was a while before I put them back in but since I have they don't work anymore!
I've cleaned the connections and when I press he button in the cab he green light comes on indicating they should be working.
I've checked the bulbs and put a multi meter on the end and it's not showing any power.
I've looked at fuses under the steering wheel and all look good but I'm now stumped!
Any ideas?
Cheers
Statey
  • wombat
05 Jan 2016 22:25 #159842 by wombat
Replied by wombat on topic Fog Light Issue
Can you trace the wiring back from the lights for a foot or so then check for voltage there. As the lights used to work it could be a bad connection when you refitted the bumper. Doubt it will be a fuse as the switch lights up.Do the bulbs work, they could have blown when disturbed taking the bumper off. :) :)
  • mickt
08 Jan 2016 19:27 #160027 by mickt
Replied by mickt on topic Fog Light Issue
Were the lights factory fitted or an after market fit using the correct light units and switch?
09 Jan 2016 11:25 #160058 by facade
Replied by facade on topic Fog Light Issue
The factory fit have a relay and fuse to the lights operated by the illuminated switch, so if the fuse is gone, or the relay is burnt out/dirty they won't come on, but the tell tale does.
I believe the front fogs have a separate fuse in an auxiliary fuse box somewhere, might be the one by the battery, or somewhere else.
The one by your feet has the fuse for the rear fog, which is different.
  • Statey
09 Jan 2016 16:55 #160078 by Statey
Replied by Statey on topic Re:Fog Light Issue
facade wrote: The factory fit have a relay and fuse to the lights operated by the illuminated switch, so if the fuse is gone, or the relay is burnt out/dirty they won't come on, but the tell tale does.
Cheers their factory fit so I'll try find this relay and fuse!
Anyone got a wiring diagram or something to help?
  • StealthJimny
09 Jan 2016 20:14 #160091 by StealthJimny
Replied by StealthJimny on topic Re:Fog Light Issue
the fuse for these was taped to my positive cable straight off the battery, hope this helps.
