Exhaust nut
  • Daniel30
10 Sep 2015 21:59 #151691 by Daniel30
Exhaust nut was created by Daniel30
Does anyone know where to get a nut to fit the bolt with the spring on it In the centre of the exhaust I have the bolt but need a nut to fit it it seems to have a weird thread need help fast getting it fitted Saturday Cheers
10 Sep 2015 22:13 #151692 by Busta
Replied by Busta on topic Exhaust nut
I had to replace the bolts on mine and a standard M10 bolt threaded in to the nut that is welded on the flange fine. It won't be anything exotic.
  • Daniel30
11 Sep 2015 05:58 - 11 Sep 2015 06:00 #151700 by Daniel30
Replied by Daniel30 on topic Exhaust nut
The bolt on the left is the same size as the exhaust bolt on the right but the nut doesn't go on the thread is different, I think the nut in the exhaust will have to come off cause the old bolt is broken off in it hence why I'm looking for a new nut for the exhaust bolt
[IMG
[IMG
Last edit: 11 Sep 2015 06:00 by Daniel30. Reason: Pic
11 Sep 2015 06:27 - 11 Sep 2015 07:02 #151701 by Halford
Replied by Halford on topic Exhaust nut
The exhaust bolt has a finer pitch, if you count the no of turns on each bolt over the same length, not sure but maybe it's metric fine 1.25mm you need, opposed to 1.5mm stamdard
Last edit: 11 Sep 2015 07:02 by Halford.
11 Sep 2015 07:35 #151702 by Busta
Halford wrote: The exhaust bolt has a finer pitch, if you count the no of turns on each bolt over the same length, not sure but maybe it's metric fine 1.25mm you need, opposed to 1.5mm stamdard
I think you are right, M10 fine.
11 Sep 2015 08:18 #151704 by X8GGY
Time to create page: 0.219 seconds
