Remove the fascia/dash?
- hora
27 Aug 2015 11:44 #150737
by hora
Remove the fascia/dash? was created by hora
I've looked everywhere- maybe my google is broken as normally such a question would bring up a host of different links and vids?!
Only found one- apparently you use a flat blade and 'snap' the fascia trim out?
27 Aug 2015 11:50 #150738
by j999pre
Grey pick up Jimny
Replied by j999pre on topic Remove the fascia/dash?
Two screws under Speedo cowl
One screw under lip above radio
Grey pick up Jimny
The following user(s) said Thank You: hora
- hora
28 Aug 2015 12:04 - 28 Aug 2015 12:05 #150837
by hora
Replied by hora on topic Remove the fascia/dash?
Cheers
- pulled the cig lighter out and found three but when you say under the speedo cowel?
Last edit: 28 Aug 2015 12:05 by hora.
28 Aug 2015 18:31 #150854
by gilburton
Replied by gilburton on topic Remove the fascia/dash?
Are you talking about the dashboard or the trim surrounding the radio??
- gusthegorilla
28 Aug 2015 18:37 #150855
by gusthegorilla
If I remember correctly, Hora's Jimny is just about new...is there a difference in the dash fitting I wonder?
Gus
Replied by gusthegorilla on topic Remove the fascia/dash?
j999pre wrote: Two screws under Speedo cowl
Gus
- hora
28 Aug 2015 18:41 #150856
by hora
Yes its a 64reg with a fake! bonnet air intake
Time to create page: 3.070 seconds
