Rear Door
- Zee Zee Top
Before they arrive I want to remove the rear trim panel to save time and reduce the risk of more damage.
Does this simply pull off? or is it a bit more complicated.
many thanks, Jean
- NineCherries
How soon are you doing it? I plan to take mine off again soon to add some sound deadening, I could take a couple of pics when it's off to show you clip location.
- Zee Zee Top
NineCherries wrote: On my 08 plate it was just pull off. Start at the bottom of the panel and work along the bottom edge, teasing it when you are close to a retaining clip. Work up both sides towards the windscreen (I think there are a couple of trim clips towards the moddle of the panel too) then take it easy along the top as mine kinda slipped under the screen rubber. It takes less than 5 mins to take off.
Thanks, pics would be great, going to have a go over the bank holiday or the next weekend.
- Tadpole
edit sorry it was the wrong door ... :whistle:
Have a search for rear wiper replacement, I think Halford/Hellijohn did it, this has pics showing pop clip positions etc.
Found it post #71590 www.bigjimny.com/index.php/forum?view=to...=8&id=17232&start=96
- Zee Zee Top
Tadpole wrote: Stored away in my 'How 2' favourites hth ...
Brill...thanks Tadpole
- Tadpole
Your very welcome, I also recently bought a set of 'tools' this set have been very useful ... ;)Zee Zee Top wrote:
