Consequences of having a steel front bumper
10 Aug 2015 14:42 #149609
by Bosanek
Consequences of having a steel front bumper was created by Bosanek
I am considering to install heavy-duty steel front bumper on my Jimny (like the well known ARB steel front bumper).
The largest advantages of having a steel bumper instead of factory plastic one would be:
1. Higher bumper -> much larger approach angle
2. Tougher looks, tougher physically as well
3. Ability to add driving lights, winches, etc.
4. No need to add any "bull bar" ("nudge bar") which would further reduce approach angle.
5. If my wife hits something in front at low speed (and she does have a habit of pushing trash containers around ....), the bumper should survive quite nicely
However, I am certain there are some disadvantages as well!
So, what would the disadvantages of having a steel bumper instead of factory plastic front bumper be?
I am thinking about these possible issues:
1. More weight on the front suspension (how much additional weight would it be)?
2. Risk of front suspension becoming "sagged" or "leaned" (I read about that issue on some forums!)
3. Legality in European Union territory? Or does it depend on country-per-country basis, even in EU?
4. Influence on car behavior during frontal impact (crush zones, airbag funcionality, etc.)
5. Influence on car handling and traction (due to additional weight up front, which is already much heavier than the rear-wheel driven back)
Have I forgotten any additional advantage or disadvantage?
The following user(s) said Thank You: NelsonB
10 Aug 2015 15:21 #149610
Replied by Daniel30 on topic Consequences of having a steel front bumper
What year is your jimny? there has been a debate on here about changing the bumper from 2007 onwards to a steel /winch bumpers
10 Aug 2015 15:38 #149612
by Bosanek
Replied by Bosanek on topic Consequences of having a steel front bumper
My Jimny was made in 2006 and has a 2nd gen front bumper (the largest / lowest one, with the smallest approach angle). It has fog lights.
The bumper has survived several hits up front in low speed (usually during turning, parking etc.) and has survived a couple of ground hits due to insufficient approach angle. It has started to come off the chassis, and will need repairs.
Therefore, I am thinking of either maybe replacing it with a 1st gen bumper (I have a chance of obtaining one), or maybe even installing a heavy duty aftermarket steel bumper instead. But I need to know the advantages and disadvantages of any solution.
15 Aug 2015 09:19 #149847
by Obarno
Replied by Obarno on topic Consequences of having a steel front bumper
Something else to consider with a larger deeper front bumper is air flow to the engine. My 2007 Jimy has a first generation ORA winch bumper with a Superwinch EP 9 winch. The bumper really restricts air flow to the bottom half of the radiator when off road and has made the engine run hot when there were very high air temperatures - Round 38 C but another consequence was that the air con didn't work properly as the air con rad kept overheating. Although the air con fan moves a lot of air it was insufficient. Not helping was my number plate which I have lowered as much as possible and I also changed the viscous coupling on the fan in case that too wasn't working properly. I also elongated 2 of the air holes in the lower part of the bumper to make them slots between 2 holes which also helped. These small improvements seem to have solved the problem, but I must point out it was very hot and we were climbing in low 2nd so the engine was working hard.
Just something to consider when you are looking at winch bumpers
18 Feb 2016 12:20 #162620
by Bosanek
Replied by Bosanek on topic Consequences of steel front bumper
Thank you very much for these observations. I never thought much about air flow with steel bumpers, as I supposed that air flow would not be an issue at all, since most steel bumpers are not deep (tall) at all.
My primary concerns were additional weight on the front suspension, and possible steering misbehavior at bends, as the front/back weight ratio would be further biased to the front on an already front-heavy car with rear wheel drive.
Did anyone else have issues with air flow when using steel bumpers?
- mc_nebula
28 Feb 2016 19:44 #163104
by mc_nebula
Replied by mc_nebula on topic Consequences of steel front bumper
I think that some metal bumpers can actually reduce the approach angle, it _looks_ like the ORA bumper potrudes further than the standard one, surely this would have an effect? Anyone got any side-on pictures?
