Anybody fitted Pro Comp shocks ?
- Grego
10 Jul 2015 15:53 #147551
by Grego
Anybody fitted Pro Comp shocks ? was created by Grego
Got a set of Pro comp ES1000 shocks to fit, but I cant figure out the rear shock bushes.
Wondering how others have fitted them?
- supergaz
10 Jul 2015 17:21 #147556
by supergaz
Replied by supergaz on topic Anybody fitted Pro Comp shocks ?
Trim the bushes down at the top. I use an orbital sander.
- Basketcase
- Thank you received: 51
10 Jul 2015 17:22 #147558
by Basketcase
Replied by Basketcase on topic Anybody fitted Pro Comp shocks ?
I butchered my ones with the grinder, still fit and worked though
- Grego
10 Jul 2015 17:50 - 10 Jul 2015 17:57 #147559
by Grego
Replied by Grego on topic Anybody fitted Pro Comp shocks ?
Problem I have is I only have 1bush per shock with an id of 12mm (33mm long), the next smallest is 13mm id, not much good with a 12mm bolt
Last edit: 10 Jul 2015 17:57 by Grego.
- Thank you received: 923
10 Jul 2015 18:13 - 10 Jul 2015 18:14 #147560
Replied by X8GGY on topic Anybody fitted Pro Comp shocks ?
OR... that nice man at Bits4Vits (Me!
) will see you some moulded the right size to fit at the top / rear of the Jimny -
www.bits4vits.co.uk/store/jimny/ring-mou...-rear/prod_1165.html
Comparison shot -
Comparison shot -
Last edit: 10 Jul 2015 18:14 by X8GGY.
- Grego
10 Jul 2015 20:14 #147565
by Grego
Hi Dave, they look like the perfect answer to an annoying problem
Its not too hard for me though as I can knock up a couple of bushes on the lathe easily enough if I need to, but I would rather have had 2 bushes to fit out the box
Particularly like your split castor correction bushes btw, neat idea
