pink injectors
- lammurai
11 years 5 months ago #145215
by lammurai
pink injectors was created by lammurai
Bought a 2000 jinny softtop
In the intake manifold are pink injectors and in the others i have are red ones
How about that?
How about that?
- gus2000
11 years 5 months ago #145248
by gus2000
Replied by gus2000 on topic pink injectors
- lammurai
11 years 5 months ago #145268
by lammurai
Replied by lammurai on topic pink injectors
Thanks for your answer.
What benefit do those have or does the jimny only do less miles a gallon?
And do you know from what car they're from?
- gus2000
11 years 5 months ago #145277
by gus2000
Hello, if the engine air filled (improved intake or exhaust, modification of the camshaft) is improved also by increasing the engine displacement, the original injectors are too small.
The ECM can increase injection time based on the reading of the lambda sensor to some extent, then it is necessary to increase the size of the injectors
APPLICATION of denso pink injectors
2002 LEXUS ES300 3.0L V6 , 2002 TOYOTA CAMRY 3.0L V6 , 2003 LEXUS ES300 3.0L V6 , 2003 TOYOTA CAMRY 3.0L V6 , 2004 LEXUS ES330 3.3L V6 , 2004 LEXUS RX330 3.3L V6 2WD , 2004 LEXUS RX330 3.3L V6 AWD , 2004 TOYOTA CAMRY 3.0L/3.3L V6 , 2004 TOYOTA SIENNA 3.3L V6 2WD , 2004 TOYOTA SIENNA 3.3L V6 AWD , 2004 TOYOTA SOLARA 3.3L V6 , 2004 TOYOTA HIGHLANDER 3.3L V6 2WD , 2004 TOYOTA HIGHLANDER 3.3L V6 4WD , 2005 LEXUS ES330 3.3L V6 , 2005 LEXUS RX330 3.3L V6 2WD , 2005 LEXUS RX330 3.3L V6 AWD , 2005 TOYOTA CAMRY 2.4L ABS , 2005 TOYOTA CAMRY 2.4L W/O ABS , 2005 TOYOTA CAMRY 3.0L/3.3L V6 , 2005 TOYOTA SIENNA 3.3L V6 2WD , 2005 TOYOTA SIENNA 3.3L V6 AWD , 2005 TOYOTA SOLARA 3.3L V6 , 2005 TOYOTA HIGHLANDER 3.3L V6 2WD , 2005 TOYOTA HIGHLANDER 3.3L V6 4WD , 2006 LEXUS ES330 3.3L V6 , 2006 LEXUS RX330 3.3L V6 2WD , 2006 LEXUS RX330 3.3L V6 AWD , 2006 LEXUS RX400h 3.3L V6 HYBRID AWD , 2006 LEXUS RX400h 3.3L V6 HYBRID RWD , 2006 TOYOTA CAMRY 3.0L/3.3L V6 , 2006 TOYOTA SIENNA 3.3L V6 2WD , 2006 TOYOTA SIENNA 3.3L V6 AWD , 2006 TOYOTA SOLARA 3.3L V6 , 2006 TOYOTA HIGHLANDER 3.3L V6 2WD , 2006 TOYOTA HIGHLANDER 3.3L V6 4WD , 2006 TOYOTA HIGHLANDER 3.3L V6 2WD HYBRID , 2006 TOYOTA HIGHLANDER 3.3L V6 4WD HYBRID , 2007 LEXUS RX400h 3.3L V6 HYBRID AWD , 2007 LEXUS RX400h 3.3L V6 HYBRID RDW , 2007 TOYOTA HIGHLANDER 3.3L V6 2WD , 2007 TOYOTA HIGHLANDER 3.3L V6 4WD , 2007 TOYOTA HIGHLANDER 3.3L V6 2WD HYBRID , 2007 TOYOTA HIGHLANDER 3.3L V6 4WD HYBRID , 2007 TOYOTA SOLARA 3.3L V6 , 2008 LEXUS RX400h 3.3L V6 HYBRID AWD , 2008 LEXUS RX400h 3.3L V6 HYBRID RWD , 2008 TOYOTA SOLARA 3.3L V6,
- minitehnicus
11 years 5 months ago #145281
by minitehnicus
Replied by minitehnicus on topic pink injectors
what is the flow of the green injectors?
- gus2000
11 years 5 months ago #145302
by gus2000
Denso-Fuel-Injector-195500-3290-for-SUZUKI-Esteem 15710 64G00 (green)
220 cc/min
220 cc/min
Time to create page: 0.088 seconds
