Revs dropping and engine cutting out. Code reader shows immobiliser issue. Key fault maybe?
19 May 2015 13:26 #144402
by minibbb
Revs dropping and engine cutting out. Code reader shows immobiliser issue. Key fault maybe? was created by minibbb
My brothers 200 jimny has an issue whereby he was driving and the revs kept dropping and the engine cut out. I suspected a crank sensor issue however the garage just called me saying the code reader shows an immobiliser issue.
He suggested maybe the aftermarket central locking kit or a faulty key could be to blame. The central locking has been on there three years without issue.
Anyone has anything similar?
19 May 2015 16:50 #144411
by j999pre
Grey pick up Jimny
Replied by j999pre on topic Revs dropping and engine cutting out. Code reader shows immobiliser issue. Key fault maybe?
Bad connection to the relay under the fuse box in the engine bay?
Grey pick up Jimny
19 May 2015 21:41 #144428
by minibbb
Cheers James- would that throw up the immobiliser code?
Replied by minibbb on topic Re:Revs dropping and engine cutting out. Code reader shows immobiliser issue. Ke...
j999pre wrote: Bad connection to the relay under the fuse box in the engine bay?
22 May 2015 08:58 #144633
by minibbb
Replied by minibbb on topic Re:Revs dropping and engine cutting out. Code reader shows immobiliser issue. Key fault maybe?
Well it didn't get any better so had the RAC out and it showed the crankshaft sensor! It's in the garage for it this morning so fingers crossed is finally sorted!
22 May 2015 09:08 #144635
Replied by Daniel30 on topic Revs dropping and engine cutting out. Code reader shows immobiliser issue. Key fault maybe?
Good luck
22 May 2015 10:11 #144640
by minibbb
Appears to be sorted!
Daniel30 wrote: Good luck
Time to create page: 0.160 seconds
