Replacement horn
  • Tomhorntoad
10 Apr 2015 21:58 #142277 by Tomhorntoad
Replacement horn was created by Tomhorntoad
My horn has gone all quiet...
Expect its to much mud/moisture from off-roading
Any body recommend a different unit?
  • markyp2000
10 Apr 2015 22:12 #142278 by markyp2000
Replied by markyp2000 on topic Replacement horn
Train horn running off a small compressor lol
  • Tomhorntoad
12 Apr 2015 01:44 #142324 by Tomhorntoad
Replied by Tomhorntoad on topic Replacement horn
So a genuine question and I get nothing positive ... Thanks guys?!
12 Apr 2015 06:20 #142325 by j999pre
Replied by j999pre on topic Replacement horn
I think there is another thread running with some things to check,
My thoughts would be
Check for power at the horn with a meter
Clean the horn and contacts
Is the airbag light on too as it could be the squib in the steering wheel
Grey pick up Jimny
  • helijohn
12 Apr 2015 18:23 #142357 by helijohn
Replied by helijohn on topic Replacement horn
Tomhorntoad wrote: So a genuine question and I get nothing positive ... Thanks guys?!
I'm here now. I think a good one is the one like this type. ebay number 391109411516 but do look for the cheapest. They fit nicely in the corner; you can just make it out in this picture (far right corner). I used a relay which I plugged the existing spades directly into.
BTW, I do have train horns running off a tank and compressor but on my Pajero; there isn't space in the Jimny for the actual trumpets.
12 Apr 2015 22:30 - 12 Apr 2015 22:44 #142365 by Casey
Replied by Casey on topic Replacement horn
No eBay APP ID and/or Cert ID defined in Kunena configurationI took Helijohn's advice, bought a cheap nautilus off ebay
and fitted it next to the existing horn. Like Helijohn I used the existing wires from the old horn to connect to a relay (few quid from a car parts shop), put a 15 amp fuse on a live from the battery and ran the final wire to earth.
I originally tried wiring the new horn to the existing wires, but there wasn't enough power and it just made a loud grating noise. Works fine though with the method above.
If you need more info just shout up.
Last edit: 12 Apr 2015 22:44 by Casey.
Time to create page: 0.484 seconds
