I need your help! - Tyre/Rim Change
  • Kieran678
12 Mar 2015 11:43 - 12 Mar 2015 12:04 #140427 by Kieran678
I need your help! - Tyre/Rim Change was created by Kieran678
I want to change the standard 15" alloys to 15" 7J steel rims and put on maxxis that have a depth of 75 instead of the standard 70. The width staying standard at 205mm. All I want to know is, will adding 5mm of tyre wall depth and going from 5.5J to 7J cause me any problems? Does any one have any experience doing this? I understand the change isn't huge but want to know 100% that they will drive perfectly with no rubbing etc etc.
If I could get a reply asap that would be great! cheers!
Kieran
Last edit: 12 Mar 2015 12:04 by Kieran678. Reason: incorrect info
  • Daniel30
12 Mar 2015 11:51 - 12 Mar 2015 11:53 #140428 by Daniel30
Replied by Daniel30 on topic I need your help! - Tyre/Rim Change
I have 205/75/15 tyres on my 15x7 steel modulars with 30mm offset though they drive fine have rubbed a couple of times when I went down some big hole on an unmade road think that's because of the 30mm offset though
Last edit: 12 Mar 2015 11:53 by Daniel30.
  • wombat
12 Mar 2015 11:59 #140429 by wombat
Replied by wombat on topic I need your help! - Tyre/Rim Change
Hi, the difference between a 205/70 tyre and a 205/75 tyre is about 10mm as the 70 and 75 are not mm but the percentage of the width (205) which determines the wall height.
hope this helps B)
  • Kieran678
12 Mar 2015 12:02 - 12 Mar 2015 12:07 #140431 by Kieran678
Replied by Kieran678 on topic I need your help! - Tyre/Rim Change
They look brilliant!! So general day to day use you have no problems? And could I ask where you got your tyres and steels from? I'm going to get the same rims so the offset should be very similar shouldn't it?
Thanks
Last edit: 12 Mar 2015 12:07 by Kieran678.
  • Kieran678
12 Mar 2015 12:05 #140433 by Kieran678
Sorry didnt mean to put 'mm' yes I see, cheers
12 Mar 2015 12:10 #140434 by Halford
Kieran you shouldn't have any rubbing problems as from your avater pic it looks likeyou've a pre-2005 model whereas Daniels has the deeper post-2005 bumper that can cause rubbing issues.
Time to create page: 0.205 seconds
