Air Con issue
  • CJV8
11 years 11 months ago #130674 by CJV8
Air Con issue was created by CJV8
I've been having an issue where the air con doesn't appear to be truly 'off' when the switch is set to off.
The heater gubbins under the dash do feel like it's been running as after a longish run things are slightly frosted up.
The only thing I can think is that following the bad weather we had in early October the amount of water we had to drive through (only about 6" deep at the most, but it was around 45mins of 2" - 6" depth) some of it got into the air con pulley, so the clutch mechanism in there is sticking.
I've looked all over the place for mention of a similar issue, but can't find it.
Other than hitting the pulley with a dead blow hammer to try and free it does anyone have an suggestions?
Time to create page: 0.069 seconds
