The best aftermarked radius arms??
- Pirate4x4
24 Sep 2014 20:54 #125004
by Pirate4x4
The best aftermarked radius arms?? was created by Pirate4x4
I have a trailmaster 2" lift and looking for new radius arms that will take beating.. witch is the best on the marked??
- TomDK
24 Sep 2014 21:07 #125005
by TomDK
Replied by TomDK on topic The best aftermarked radius arms??
Have you considered just using standard Jimny with castor correcting bushes?
Zanfi are probably some of the best, but also the most expensive.
I've been told Suzuki also makes some for racing use. I can find out more about this tomorrow.
- Pirate4x4
24 Sep 2014 21:34 #125011
by Pirate4x4
Replied by Pirate4x4 on topic The best aftermarked radius arms??
I have to day a set from Offroad Armoury, tubular.. and I have slightly bent one in the aft!!
- darthloachie
25 Sep 2014 10:48 #125050
by darthloachie
Replied by darthloachie on topic The best aftermarked radius arms??
- Pirate4x4
25 Sep 2014 13:14 - 25 Sep 2014 13:15 #125060
by Pirate4x4
Looking good.. but I see that they are made for lift up to 4" mine has a trailmaster 2" kit...
Mine was mounted this spring and the car has bearly been used.. having some service on the car yeasterday I saw that one of the rear raduis arms has a slight bend (1cm) and there is no dents in the tubes so it does not look like they have been in contact with stones or somethin like that...
The car is now parked until I find a solution for this...
Mine was ols style ORA, but totaly unused before I mounted them this spring
img.tapatalk.com/d/13/12/22/aqepapu5.jpg
Last edit: 25 Sep 2014 13:15 by Pirate4x4.
- darthloachie
25 Sep 2014 14:08 #125063
by darthloachie
ORA used give lifetime guarantees on their radius arms so it might be worth ringing them
I think you can order the amount of castor correction on the Rhinorays arms
Time to create page: 0.208 seconds
