Abs light on
- hunter1084
29 Apr 2014 00:47 #113659
by hunter1084
Abs light on was created by hunter1084
I have a 2013 Jimny and the ABS light has just come on yet the ABS seems to be working, any ideas what might have caused this?
- markyp2000
29 Apr 2014 17:14 #113703
by markyp2000
Replied by markyp2000 on topic Abs light on
If the light is on then it shouldnt work
abs normaly starts works over 20 to 30mph find a loose surface road drive over 30 and stamp on the brakes that will tell you if it working
also iv seen the wires to the abs sensor on the front hubs get pinched on the hub and brake the wire
another test you can do is a resistance test with a multi meter and see if one of the sensors has a different reading from the rest
- Basketcase
- Thank you received: 51
29 Apr 2014 17:23 #113704
by Basketcase
Replied by Basketcase on topic Abs light on
Check the brake fluid if that's full take it back to a dealer or you'll void warranty
The following user(s) said Thank You: hunter1084
- markyp2000
29 Apr 2014 17:50 #113709
by markyp2000
lol i didnt see the year :laugh:
Basketcase wrote: Check the brake fluid if that's full take it back to a dealer or you'll void warranty
- hunter1084
29 Apr 2014 23:03 #113769
by hunter1084
Replied by hunter1084 on topic Abs light on
Cheers for the replies found the problem, the wire that comes of the rear left wheel and runs up the arms to the plug had been pulled out of the plug itself so shes going up tomorrow to get fixed :laugh:
- Basketcase
30 Apr 2014 18:47 #113811
by Basketcase
Nice warranty job for local dealer there haha
Time to create page: 0.235 seconds
