king pin help
  • 410shotgun
12 years 9 months ago #104097 by 410shotgun
king pin help was created by 410shotgun
just found out I have a small amount of up & down play in my o/s bottom
king pin how hard are they to do
I also have a wobble on the steering at 50 mph do you think it is this
  • GuardianAngel
12 years 9 months ago #104099 by GuardianAngel
Replied by GuardianAngel on topic king pin help
Easy but messy and stinky. There is a how to guide link from the main page of the site.
Wobble could be the KP's but other things can also cause it. There is a Death Wobble sticky thread in the Technical section of the site.
  • MWells
12 years 9 months ago #104102 by MWells
Replied by MWells on topic king pin help
It's a fairly straight forward job unless like me you sheer half a dozen bolts trying to undo them even after soaking in penetrating oil. Follow the guide and have lots of disposable gloves and paper towel to hand and it should be ok.
  • Yellostreak
12 years 9 months ago #104103 by Yellostreak
Replied by Yellostreak on topic king pin help
Just a tip - I usually stick a cardboard box under my hub so that when I start to dismantle all the gunge and some of the bits fall into it.. its also a place to drop your throw away rags (they won't survive!).. then once you have checked there are no important bits in the box throw the whole lot in the bin!
bloomin messy and smelly job for sure..
  • 410shotgun
12 years 9 months ago #104189 by 410shotgun
Replied by 410shotgun on topic king pin help
its only up and down play could I shim this to remove the play like on the land rover ?
  • Yellostreak
12 years 9 months ago #104190 by Yellostreak
410shotgun wrote: its only up and down play could I shim this to remove the play like on the land rover ?
it works the opposite way around to a landrover.. the LR you have to remove shims to tighten up the bearing, on the jimny you can add a copper washer behind the bearing to push it tighter into the race.. generally speaking though its knackered at that point anyway so most people just change the seal and bearings.. not a big job to do and proably needed because if there is play in the kingpin bearings chances are the axle seal is shot and peeing out sludge from the back of the swivel..
Time to create page: 0.090 seconds
