Snorkel question??
12 years 9 months ago #103374 by Jimbospanner
Hello all,
I have a question that I hope the vast knowledge out there could answer.
I have full role cage that you can see in the picture, if I was to fit a snorkel, how would this be done.
Due to the cage, I'm guessing it would be a Self constructed version?
Does anybody know of systems that are available to purchase that are ready made?
Thanks for any help!
  • Bazcam
12 years 9 months ago #103414 by Bazcam
Replied by Bazcam on topic Snorkel question??
Due to that cool roll cage you have you'll have to make a custom snorkel
I reckon. None of the kits will work with the tube running along the wing
like that.
Its no biggie really, once you remove the resonator ( if your model has a resonator )
from between the inner and outer wing there's loads of room to run a tube and out the
top of the wing or wherever.
Any more pics of your jimny or a build thread anywhere?
  • idiotmobil
12 years 9 months ago #103425 by idiotmobil
Replied by idiotmobil on topic Snorkel question??
theres been this discussion quite recently im sure he got a normal one and made it fit but cant remember who it was have a search
12 years 9 months ago #103436 by Jimbospanner
Replied by Jimbospanner on topic Snorkel question??
I'll keep looking for that discussion topic. I've seen one but e did not have a bar running along the wing. Thanks idiotmobil.
Bazcam some more pis for you, got the jimny with quite a lot of work done, 3" lift, cage, winch, bumper and front correction arms.
I've done work on engine (overheating) rear axle, pan rods, rear shock position and a CB. Oh yes, leaking front axle seal and rear axel input seal.
The following user(s) said Thank You: Bazcam
  • Dorfl
12 years 9 months ago #103445 by Dorfl
Replied by Dorfl on topic Snorkel question??
I would run a pipe inside the wing, out just behind the A of the AWDC sticker. then clamp/cable tie to the cage up the A pillar. Mine is a Airtec (TJM) cable tied to the cage. but i don't have the bar across the wing.
12 years 9 months ago #103491 by Jimbospanner
Thanks, the bar across the wing does give a stronger cage, but does not take into account a snorkel like you said.
I know if I tried to work something like what you said, it would look shit, and prob not even work.
Where do you purchase kits from?
Time to create page: 0.101 seconds
